Alnico A5 magnet to match Evo bridge - Jemsite
post #1 of 7 (permalink) Old 06-17-2017, 07:14 PM Thread Starter
Hey all,
Speccing out a custom guitar and having trouble deciding which pickups to put in it. I love the Evo in the bridge position for rhythms and leads, especially with heavier/darker sounding woods as it's a trebley pickup. I am not that big of a fan of the Evo in the neck position - granted it's great on full volume, but I like to roll off the volume a lot for melody sections, and the clean tones of the A5 Bareknuckle simply blows the Evo out of the water. The clean-up of the Bareknuckle Nailbomb in the neck position is marvellous.
Does anyone know if 1. An Evo & A5 Nailbomb match up would work; or 2. of an Alnico pickup hot enough/with enough output to put in the neck position and match an Evo in the bridge position. Obviously, I don't want the volume dropping off when I change pickup selection.
Cheers
Craig
Craig_Shaft is offline
post #2 of 7 (permalink) Old 06-18-2017, 10:39 PM
Reviews: 120
Re: Alnico A5 magnet to match Evo bridge
Originally Posted by Craig_Shaft View Post
Hey all,
Cheers
Craig
From memory, it's been said that the PAF Pro with a ceramic magnet enters Evolution territory, like a baby Evo. Maybe a stock PAF Pro, with it's alnico 5 magnet, in the neck will suited. May just need to raise a bit to match.
LonePhantom is offline
post #3 of 7 (permalink) Old 06-19-2017, 03:12 AM
Humm. I find that the Evo DP158 neck matches well with the Evo DP159 bridge. The DP158 has a great clean tone even though it's a ceramic pickup. But if you are set on Alnico 5 magnets try the DP 213 PAF Joe. It's sweet.
aoresteen is offline
post #4 of 7 (permalink) Old 06-19-2017, 04:34 AM
Maybe you should put some bridge version of A5 in neck position. Like Gravity Storm or similar.
peromucho7 is offline
post #5 of 7 (permalink) Old 06-23-2017, 02:08 PM
The PAF Pro or PAF Joe would have been my first thought here too, but if you like the Nailbomb in the neck overall, then it's worth a shot - you have to have some pretty major volume mismatches before you get to the point where you can't make it work, and I like to have somewhat different sounding neck and bridge pickups.
Drew is offline
post #6 of 7 (permalink) Old 06-28-2017, 03:28 PM
rgr
I'd go with a stock PAF Pro, A5 magnet and it's pretty much the same output as the Evo neck model.
rgr is offline
post #7 of 7 (permalink) Old 06-28-2017, 05:24 PM
Reviews: 6
paf pro, paf joe or breed neck.
I had the pro and the joe paired with an EVO2 in a RG550: I prefered the joe but this one is more rock n' roll than "hard rock/heavy metal" oriented as the EVO2 is.
The pro lacked of balls to my ears.
I eventually found a match with the EVO neck.
Bt try the breed neck, it might fit your expectations
satch_jr is offline
bareknuckle , custom , daemoness , dimarzio , seymour duncan
Dimarzio Evo with a Alnico 8 Magnet Rocks Angelus502 Pickups & wiring 3 10-22-2015 12:08 AM
Magnet Swap for stock V7/V8 pickups...Alnico 8? ijustwntit Pickups & wiring 7 07-16-2011 03:54 AM
The perfect match for my Evo bridge? shrediqette Pickups & wiring 9 04-19-2008 10:48 PM
FS : Screaming Demon with ALNICO 8 magnet !!! fab.regnaut Classified Ads: Guitars and Gear 1 03-03-2006 04:25 PM
Anyone know what year Gibson switched from Alnico II to V magnet pickups? red5 Gear, Equipment, Recording & Off Topic 6 07-03-2005 04:41 PM
