amp line out sound quality - Jemsite
post #1 of 1 (permalink) Old 11-21-2012, 10:04 PM Thread Starter
Hi All,
I have a couple heads that I have been using the line out to go to rack effects, into a power amp that feeds two cabs. Sounds good but I always wonder if the line out is the way to go. When I go direct from head to cab with speaker outs, the sound is a little more defined. When I use the loop, I get noise and hum.
Without considering hum for the moment, would you prefer using the effects loop for eqs, and then use the line out for the rest of the effects? Have you experienced any difference in tone using a line out?
I also have an weber attenuator with a line out that I could try to see if that sounds better since I would be using the speaker outs in that case. It doesn't solve the crazy noise and hum from my effects loop when I connect my rack eqs though. Any advice would be greatly appreciated. Thanks, Pete
pforsell is offline
amp , line out , loop
DAWS and Sound Quality 6fingers Gear, Equipment, Recording & Off Topic 15 06-29-2012 10:56 AM
How much does sound quality vary between pickups of the same model? jem7vwh Tech: Setup, Repairs and Mods 1 05-17-2012 08:57 PM
what mp3 players have the best sound quality? AlexBLA Off-topic / Miscellaneous 17 11-02-2005 07:44 PM
need a studio-quality PC sound card Max-T Gear, Equipment, Recording & Off Topic 9 08-11-2004 04:59 AM
Line 6 Pod/Johnson J-station - Tone Quality? Anonymous Gear, Equipment, Recording & Off Topic 5 05-11-2001 10:25 AM
