amp problem - Jemsite
post #1 of 4 (permalink) Old 12-26-2005, 07:52 AM Thread Starter
amp problem
i have a fender blues deville, i can't get power on it anymore, that is: the red light that's suposed to burn when turned on doesn't light up anymore, and the amp doesn't work offcourse. I tried plugging it in in different places, doesn't work. It's not the electricity in my house that's off, cuz all other electric equipment works. I'm guessing the amp's fuse blew? Are there any other obvious possible reasons i'm missing here ?
It's a new amp, i've only had it for 2 days!
Tom B is offline
post #2 of 4 (permalink) Old 12-26-2005, 07:56 AM
Re: amp problem
Could be a blown fuse to something going wrong in the amp itself, it happens with tube amps if a tube goes. If its 2 days old, take it back.
Ant1981 is offline
post #3 of 4 (permalink) Old 12-26-2005, 08:12 AM Thread Starter
Re: amp problem
yeah the problem is that i bought it in a shop that's a one hour drive away, while if it's just a fuse, i could go to a shop that's closer by
Tom B is offline
post #4 of 4 (permalink) Old 12-26-2005, 08:24 AM
Re: amp problem
You could do, but what if the fuse blows again, you have to think something caused it to blow in the first place. It's not an easy one considering the shop is an hour away, speak to them on the phone, it may be the best option to go there, just drive carefully!
Ant1981 is offline
tube amp , tube amps
problem with PM's? evolvedmb Forum Announcements and Member Help 0 03-17-2008 06:30 AM
problem with EMG ZW set kral Pickups & wiring 1 09-02-2004 05:22 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
Any problem setting up for BEADGB? - Any problem setting up Pudreaux Ibanez JEM, UV, JS & Other Signature Models 2 06-28-2001 02:56 PM
