Amps with Separate Bias Points Per Power Tube? - Jemsite
post #1 of 1 (permalink) Old 09-21-2009, 03:09 AM Thread Starter
Reviews: 23
Lightbulb Amps with Separate Bias Points Per Power Tube?
Hello y'all, I was fooling around with google and stumbled upon this website: www.fortinamps.com
And so I checked it out and found pics of amplifier heads, got interested, and decided to read the specs of the products. I found that one of the features of all the amps was that it had 4 separate bias pots and test points for each power tube.
I was assuming that this makes buying, installing, and biasing power tubes easier, plus the site claims that the amps can run in different combinations of power tubes installed (I thought of this as probably being able to run EL34, 6L6, KT66, or KT88 tubes side by side, for example?).
While I am pretty satisfied with my gear for now, maybe some of you guys would like to check it out for yourselves.
theapprentice is offline
amplifier , bias , power tube
Low power/low wattage tube amps slugman Gear, Equipment, Recording & Off Topic 27 09-17-2006 01:17 PM
HELP: Need scan of Marshall 20/20 Power Amp bias sticker JiMoSiTY Gear, Equipment, Recording & Off Topic 0 05-19-2006 01:01 PM
Tube power amps adamcbest Gear, Equipment, Recording & Off Topic 3 11-11-2005 04:46 PM
Tube power amps - Save up for the Mesa, or save $ with the M bduersch Gear, Equipment, Recording & Off Topic 4 07-16-2001 05:38 PM
Power supplies, preamps and power amps - whats the more idea tomizm Tech: Setup, Repairs and Mods 2 04-11-2001 06:56 PM
