another stupid sound card question - Jemsite
post #1 of 8 (permalink) Old 08-03-2005, 01:22 AM Thread Starter
Talking another stupid sound card question
i got a sound card in my pc, and it has an input jack, its 1/4 inch of course, but does it have to be a specail sound card ?
guitarshredder7 is offline
post #2 of 8 (permalink) Old 08-03-2005, 04:54 AM
Re: another stupid sound card question
What type of card is it? I guess you are using it to record audio on your PC. What is the problem?
David Ho is offline
post #3 of 8 (permalink) Old 08-03-2005, 05:40 AM Thread Starter
theres no problem its the card thats on the motherboard. i havnt tried it yet, but im just wondering if i need a specail card or will this one work
post #4 of 8 (permalink) Old 08-03-2005, 05:45 AM
Mobo built-in sound card (good old sound blaster compatible), is usually not the first choice for audio recording. You can use it but may run into latency problems (delay caused by analog-digital signal conversion) and in general you may suffer with overall sound quality. You are also limited in number of inputs which in this case - only one.
If you haven't done it before, you can try recording with it, but many people go straight to buying a separate PCI audio card for better performance and quality.
David Ho is offline
post #5 of 8 (permalink) Old 08-03-2005, 05:47 AM Thread Starter
sounds good ill try it and then buy a creative labs sound card. not a problem. anything else i should know
post #6 of 8 (permalink) Old 08-03-2005, 05:58 AM
I don't advise you to get a Sound Blaster card, because it's pretty much similar to the built-in card on your mobo. Try the motherboard built-in audio first and see if you like the results. I suppose new motherboards have better soundcards these days... If it works for you, no need to spend the cash, right?
I tried it before (long time ago) with a SB32 but I ended up buying an Echo Darla (discontinued now). You can find those cheap on auction sites. But of course the best way is to buy the latest stuff (better technology): M-Audio, Echo, Audiophile and a whole bunch of other vendors out there makes great inexpensive cards. Check other threads on jemsite because many people posted this subject before. Good Luck!
David Ho is offline
post #7 of 8 (permalink) Old 08-03-2005, 07:11 AM
I'm with David. 2 popular ones in the low $100's are the M-Audio Audiophile and the Echo Mia.
JESTER700 is offline
post #8 of 8 (permalink) Old 08-03-2005, 07:18 AM Thread Starter
nice thanks for the help
audio audiophile
Installing Sound Card Guitarmiester Gear, Equipment, Recording & Off Topic 11 09-13-2006 10:53 AM
M-Audio Sound Card? Darren Wonnacott Gear, Equipment, Recording & Off Topic 8 02-27-2006 08:44 PM
How good will a new sound card be, what to get? themaidenmaniac Gear, Equipment, Recording & Off Topic 15 01-15-2006 06:15 AM
I have a good sound card so could I.... Jemani Gear, Equipment, Recording & Off Topic 1 03-12-2005 06:23 PM
Sound card advice. keith Gear, Equipment, Recording & Off Topic 2 03-24-2003 03:40 PM
