Anyway to modify Boss pedals for true bypass? - Jemsite
post #1 of 2 (permalink) Old 11-20-2002, 09:10 PM Thread Starter
I love my Boss pedals, but I hate that they're not true bypass. Is there any way to modify them to make them true bypass but still keep the other characteristics and circuitry of the pedal like it was before? If so, where and how much does it cost?
Drache713 is offline
post #2 of 2 (permalink) Old 11-21-2002, 01:22 PM
rgr
The easiest way is to build a little switch box that puts the pedal in and out of a loop. That said, Boss pedals are fine the way they are, the buffer circuit in them can be a good thing, especially if you have a string of pedals then a 20ft cable to your amp, the buffer helps keep the cable losses down.
$0.02,
Roger
rgr is offline
boss pedal , boss pedals
Effect Pedals with True Bypass causing loud Pop SpikeSocietySucks Gear, Equipment, Recording & Off Topic 6 01-11-2014 10:02 AM
True Bypass, Do you really need it? Lussy Picker Polls 9 03-10-2010 03:35 PM
difference between true bypass and true hardwire bypass? Valhalla Gear, Equipment, Recording & Off Topic 0 10-15-2008 09:42 PM
True Bypass Question nix17 Gear, Equipment, Recording & Off Topic 8 11-22-2007 03:18 PM
Ibanez Wh10 Wah true bypass - how to install true bypass? stratman Gear, Equipment, Recording & Off Topic 1 01-04-2001 06:28 PM
