Appropriate wattage cab for bass head - Jemsite
post #1 of 7 (permalink) Old 11-09-2007, 02:12 PM Thread Starter
I have a 700 watt bass head, is there a minimum wattage cab that it'll go into or is it just minimum ohms?
NeglectedField is offline
post #2 of 7 (permalink) Old 11-09-2007, 02:16 PM
Re: Appropriate wattage cab for bass head
What kind of amp is it..... model/brand? I know this sounds like a stupid question but it will help in getting a correct answer.
jemplayer55 is offline
post #3 of 7 (permalink) Old 11-09-2007, 02:22 PM
If it's a SWR.... check here
http://www.swrsound.com/products/sea...tno=4450000010
http://www.swrsound.com/products/sea...tno=4410500400
post #4 of 7 (permalink) Old 11-09-2007, 04:06 PM Thread Starter
Peavey Tour 700. 700 watt amp head.
post #5 of 7 (permalink) Old 11-09-2007, 04:15 PM
500 watts into 8 ohms
700 watts into 4 ohms (4-ohm minimum load)
http://www.peavey.com/news/article.c...5/20061701.cfm
You can run any cabinet as long as it's rated at 4 ohms or above. But if it will only handle 100 watts of power you're not going to be able to push the amp to it's limits...... Did you have a cabinet or speaker combination in mind?
post #6 of 7 (permalink) Old 11-10-2007, 10:52 AM
ScottB's Avatar
Laney Nexus NX410. 800w @ 4 ohms.
http://www.laney.co.uk/show_prod.php?prod=nx410
ScottB is offline
post #7 of 7 (permalink) Old 11-10-2007, 11:56 AM Thread Starter
Nah, just wanna run it into a 4x12 or something.
amp head
WTT: Any all tube head for Carvin VL100 [Legacy] AKMG Classified Ads: Guitars and Gear 0 09-24-2006 04:48 PM
WTB: Cheap tube head or Peavey Valveking AKMG Classified Ads: Guitars and Gear 0 08-20-2006 06:32 PM
FS/FT: Ibanez TB100H Toneblaster Guitar Head revsharp777 Classified Ads: Guitars and Gear 10 08-12-2005 05:52 PM
FS/FT: Rock Hard Road Case for Amp Head JiMoSiTY Classified Ads: Guitars and Gear 0 06-10-2005 03:18 PM
MKIIC+ head F/S $1750 B/O DTSteve Classified Ads: Guitars and Gear 3 05-15-2005 07:31 PM
