Audiophile and latency problems! - Jemsite
post #1 of 5 (permalink) Old 12-29-2002, 08:36 PM Thread Starter
I got a Audiophile 24/96 recording card and a M-audio audio buddy direct box for christmas. I installed the card and it works fine. I currently have the Guitar => direct box => Input on Card. I tried both a demo of Cubase and N-track studio, and both have long latency problems. The card specifically says "zero latency" and I was wondering how I need to change the buffers (they seem to affect this) or what else I can do to fix the problem. I am very new at computer recording, so be kind =)
Thanks.
Opeth is offline
post #2 of 5 (permalink) Old 01-09-2003, 03:29 AM
first off, good choice on the gear, the 2496 is a great card and the direct box is a great lil unit.
What do you have your buffers set at in the Control panel in midiman's mixer. Lock your rate and prefereably play at 128 or 256 for your buffers. Make sure you have the proper driver chosen in Cubase under the VST tabs (midiman asio driver)
Right now my midiman is very stable at 5ms under high loads (p4 2. and the card always impresses me with it's great fidelity.
You may have to be more speicific with what options you have tweaked or not. Can you also list your other hardware and OS?
Try what I said and if not post again in this thread and Ill try help as much as I can.
gemini8026 is offline
post #3 of 5 (permalink) Old 01-12-2003, 02:38 PM
What software are you guys running with your M-Audio products?
30yroldpig is offline
post #4 of 5 (permalink) Old 01-14-2003, 06:15 PM
Audiophile 2496 + Cubase VST 5 on a MAC G4
No Latency problems at all using ASIO 2.
Ant711UK is offline
post #5 of 5 (permalink) Old 01-15-2003, 07:42 PM
1st make sure you're using the mfg provided ASIO driver specific to the exact model of card you have in lieu of any "other" driver...
ardell henderson is offline
Will a new soundcard solve my latency problem? ironfistx Gear, Equipment, Recording & Off Topic 37 01-06-2013 12:29 PM
Eventide H3000-getting around the latency Anthony Xander Gear, Equipment, Recording & Off Topic 0 03-06-2010 02:59 PM
Recording Guitar to PC via LIGHTSNAkE Latency issues plus more help !!! IbanezFreak777 Gear, Equipment, Recording & Off Topic 5 02-25-2010 05:14 PM
Panama+ Latency issues Dug Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 15 08-28-2006 09:58 PM
Any one use the L6 Guitar Port? Latency problems here. jemuniverse777 Gear, Equipment, Recording & Off Topic 2 12-30-2005 03:29 PM
