Bad horsie pedal sound? - Jemsite
post #1 of 7 (permalink) Old 08-14-2003, 11:50 PM Thread Starter
I am thinking swapping my cry baby for a bad horsie pedal but have heard mixed reports on the sound i just wondered if any one could explain the difference in tone of the two. but would i still get the right sound for the solo in sweet child of mine? Thanks for any help.
mingincorn is offline
post #2 of 7 (permalink) Old 08-15-2003, 12:09 AM
I like the crybaby for playing stuff on the high strings and the bad horsie (contour mode) for chords and low string stuff.
Jeff is offline
post #3 of 7 (permalink) Old 08-15-2003, 05:43 AM
when i had a go on one it seemed to have quite a narrow(sp?) range without using the contour and setting the range alot higher, but i only had a little go on one quite a while ago. Go and try one out for yourself
AARRGGHHH is offline
post #4 of 7 (permalink) Old 08-15-2003, 07:42 AM
Ive got one i bought second hand off ebay( BH1). Its quite good but i would say check out other pedals. It does indeed have quite a narrow range and you cant rock the pedal back and forth and expect to get a wah sound, its more a case of finding a point then rocking it a few cm either way.
Id personally look into the BH2 contour as you can change the settings etc
Swirly is offline
post #5 of 7 (permalink) Old 08-15-2003, 10:18 PM
I've got both a crybaby and a BH2. The BH2 is the pedal I prefer but, it is either on or off regardless of the contour setting. The contour seems to drive the sound more; but its sad that there is so much pedal sweep physically yet the sweep is so sharp.
windows2thesoul is offline
post #6 of 7 (permalink) Old 08-19-2003, 06:34 AM
The way I see it the Crbaby goes "wah" and the
Bad Horsie goes "wow"
vaithebook is offline
post #7 of 7 (permalink) Old 08-29-2003, 07:16 AM
Dunlop 535Q, it will do everything you ever need, I personally don't like the switchless wah's. Its sound more musical coming in on the top range of the sweep IMO.
The 535Q has 20db boost, contour modes, volume and tone pots - killer.
strat110 is offline
high strings
FS: Morley Steve Vai Bad Horsie Wah Pedal guitarscott Classified Ads: Guitars and Gear 2 02-11-2011 02:00 PM
i need help from bad horsie pedal owner lonewolf Gear, Equipment, Recording & Off Topic 5 06-19-2009 11:26 AM
FS: Morley Bad Horsie Wah pedal Davey Classified Ads: Guitars and Gear 4 12-08-2005 06:52 AM
FS: Morley Bad Horsie 2 Wah Pedal Maggot Classified Ads: Guitars and Gear 0 05-02-2005 12:02 AM
Gaaah! Stupid Bad Horsie pedal... AdamBilz Gear, Equipment, Recording & Off Topic 8 01-06-2003 06:05 PM
