BAMMBAMM, How do you connect your rack wah in signal chain? - Jemsite
post #1 of 10 (permalink) Old 09-09-2007, 10:03 AM Thread Starter
megadeth's Avatar
Please tell me about your rack setup.
Thanks,
Kanishk
megadeth is offline
post #2 of 10 (permalink) Old 09-09-2007, 10:19 AM
Re: BAMMBAMM, How do you connect your rack wah in signal chain?
The same way as a non-rack wah .
guitar - wireless - wah - triaxis - gmajor - 2.90 - cabs .
TREVA is offline
post #3 of 10 (permalink) Old 09-09-2007, 11:22 AM
sorry I didn't know BAMMBAMM is a member !!!
TREVA is offline
post #4 of 10 (permalink) Old 09-09-2007, 11:24 AM
Treva is right.
it's the 1st item after your guitar.
Mine is setup like this:
Guitar Dunlop rack in, Dunlop Wet-boost out to Triaxis, Triaxis to Mesa 2:90 to speak cab.
Mesa Triaxis Loop send to Gmajor in (mono, stero outs to MXR Digital Time delay to right side loop return, and left return from Gmajor.
This method makes my MXR effects sound larger as I'm using a stereo setup.
I have on older, HEAVY Peavy cab split for stereo with 4X G-12-85s each side paralleled. Close micing really sounds great on this cab in this config, but you need 2-4 mics depending on how you prefer micing.
I have some sound clips on my site: www.dnr-music.com under samples. 'Predator' should have some wah on it.
lemme know if you have any more questions.
Bamm
bammbamm is offline
post #5 of 10 (permalink) Old 09-09-2007, 01:09 PM Thread Starter
megadeth's Avatar
cool !!
Thanks man !
I am thinking something on these lines now...
Guitar->EQ Pedal->rack wah->assorted pedals->triaxis->G-major (not fx loop)->stereo out to poweramp-> marshall 4x12.
I may use a hotplate too.
megadeth is offline
post #6 of 10 (permalink) Old 09-09-2007, 02:30 PM
YOu don't need an EQ pedal if you have a triaxis. amd why wouldn't you use the fx loop, it's there to give you flexibility. You limit yourself by NOT using it.
THe triaxis is capable of turning on and off the loop.
bammbamm is offline
post #7 of 10 (permalink) Old 09-09-2007, 03:43 PM
ME.
Is Dunlop the only manufacturer of a rack-wah?
Colin
ME. is offline
post #8 of 10 (permalink) Old 09-09-2007, 08:59 PM
In mass quantities, I'm inclined to say yes, I've only seen others that are custom made or home made.
bammbamm is offline
post #9 of 10 (permalink) Old 09-10-2007, 10:10 AM Thread Starter
megadeth's Avatar
ohk. I read somewhere that fx-loop tends to sucks the power out of preamp. When I used it long back my volume seemed to go down BIG TIME when I used fx loop.
megadeth is offline
post #10 of 10 (permalink) Old 09-10-2007, 10:12 PM
Then you need to adjust your effects to provide the signal back at the level you sent it. Nudge up your input or output to the return.
You're going to lose more if you run it from your direct out to the power amp, you also lose headroom when you nudge up the volume out to the power amp.
The effects will clip long before your volume is at a likable level.
bammbamm is offline
mesa triaxis , power amp , rack setup , rack wah
Pedal placement in signal chain carlos seo Gear, Equipment, Recording & Off Topic 13 04-08-2009 02:09 PM
BBE 462 in signal chain Draco Gear, Equipment, Recording & Off Topic 1 09-09-2006 08:37 PM
signal chain question Elliseye Gear, Equipment, Recording & Off Topic 2 08-27-2006 02:54 AM
Running a reverb/delay in the signal chain Jeff Gear, Equipment, Recording & Off Topic 9 08-23-2003 02:42 PM
Rack signal chain question - splitting signal to tuner luther Gear, Equipment, Recording & Off Topic 4 12-14-2000 11:06 AM
