Bass amp for use with guitar? - Jemsite
post #1 of 26 (permalink) Old 07-18-2011, 08:44 PM Thread Starter
Allright. Well, I all of a sudden had this crazy idea about .. what if .. you were to stick a guitar into a bass amp?! Answer: You get a nice bottom on the thing, while keeping all the tonal values. However, I did not try to plug in any of my pedals, to use my distortion and such. I do not care for using an amps distortion. So i thought, if I could get an amazing clean sound from a bass amp, and then run my pedals through it. Would it be worthwhile? Any of you fellow jemsiters tried this out? What are your tips and tricks? I'd love to suck in all knowledge I can!
Edit: Another thing is, that you get a nice equalizer with it, instead of a three-band, of course. Well what are your thoughts?
Gladhed is offline
post #2 of 26 (permalink) Old 07-18-2011, 10:25 PM
Reviews: 98
Re: Bass amp for use with guitar?
I had to do that in 1985 when my amp died before a show. Works just fine. As far as getting more bottom end--that's not necessarily going to happen just because it's a bass amp. The bass itself plus the beefier strings, etc make that happen. You can run whatever effects you want into it--it's just an amp. You're not going to hear much difference between a bass amp or guitar amp with a guitar plugged into it.
AlaskaBat is offline
post #3 of 26 (permalink) Old 07-18-2011, 11:06 PM
Reviews: 4
the EQ is calibrated differently, so just don't touch that too much.
fwd0120 is offline
post #4 of 26 (permalink) Old 07-19-2011, 12:06 AM
Ummmm... how about a Fender Bassman?
jallen is offline
post #5 of 26 (permalink) Old 07-19-2011, 12:19 AM
Reviews: 98
Just different frequencies. Just need to flatten all EQ settings and then run whatever outboard effects and EQ. Basically just using it as a power amp.
post #6 of 26 (permalink) Old 07-19-2011, 12:43 AM
Reviews: 34
I know of one studio that uses a Marshall bass head for guitar.
Works fine apparently.
nickcoumbe is offline
post #7 of 26 (permalink) Old 07-19-2011, 03:02 AM
Reviews: 120
Plenty of people have probably used bass amps over the years, namely the Fender Bassman. Weren't the original Marshalls based off this?
I used an old cheap bass amp for a while in my teens. Got it for nothing, and was loud enough for me to play with my band. Did the job.
LonePhantom is offline
post #8 of 26 (permalink) Old 07-19-2011, 03:39 AM
what happens if it was the other way around, a bass on a guitar amp? how would it sound?
VAustin89 is offline
post #9 of 26 (permalink) Old 07-19-2011, 03:53 AM
Reviews: 98
Go down to SM Mega-Mall to the music store and find out. Or, the music store at Robinson Mall.....Kumosta Ka?????
post #10 of 26 (permalink) Old 07-19-2011, 04:41 AM
cant do that stuck on work... i guess i'll sacrifice my 10watt crapAmp.. and see what happens.. haha..
(do you speak filipino?? )
post #11 of 26 (permalink) Old 07-19-2011, 05:15 AM Thread Starter
I've tried that with a Roland something, something. It doesn't give the excact same bottom-end as a huge old Marshall.
Gladhed is offline
post #12 of 26 (permalink) Old 07-19-2011, 05:19 AM
does it damage the guitar amp?
post #13 of 26 (permalink) Old 07-19-2011, 05:21 AM Thread Starter
That would probably depend on how much you turn it up. It hasn't damaged this one, as I still crank it to eleven every once in a while with a guitar! But, eh .. I wouldn't suggest turning it up too loud.
Gladhed is offline
post #14 of 26 (permalink) Old 07-19-2011, 05:31 AM
thanks!
post #15 of 26 (permalink) Old 07-19-2011, 06:21 AM
Reviews: 98
...only when I'm drinking Royal Tru-Orange, eating adobo and watching TFC!
amplifier , bass , guitar
bass cab for guitar amp scotte_za Gear, Equipment, Recording & Off Topic 7 06-22-2007 07:53 AM
bass cab vs guitar cab nott^^ Gear, Equipment, Recording & Off Topic 0 01-11-2007 07:52 PM
Guitar through a bass amp Labrie Gear, Equipment, Recording & Off Topic 6 09-20-2005 04:54 PM
Bass? Guitar? Both? Wound All Other Guitars (including Prestige) 16 05-13-2003 04:33 AM
Bass Guitar - And Amp Two hands31 Gear, Equipment, Recording & Off Topic 0 08-12-2001 08:07 PM
