Beginner Cubase VST 4.0 problem - Jemsite
post #1 of 2 (permalink) Old 11-29-2005, 12:05 PM Thread Starter
Hi,
when I wan't to record a song over a backing track I copy my backing track into a stereo track , and I create an empty backing track for guitar ...After I record guitar on that empty track there is a delay of 0.7 s on my guitar trick wich is A LOT , and I dont want latency !
What can I do ?
Specs are :
P 4 3.6 Ghz
1 Gb DDR 2 Ram
Gforce 7800 GT
+ Line 6 Flextone II + Ibanez Jem 7 D Bk
Ty !
Not2secure4u
not2secure4u is offline
post #2 of 2 (permalink) Old 11-29-2005, 12:35 PM
Re: Beginner Cubase VST 4.0 problem
I'm no pro with Cubase but I have used it a bit for exactly what you are doing. The first thing I would do is check the driver that Cubase is using with your soundcard. For best results with lowest latency factor, you want to be using an ASIO (such as in my case M Audio Delta Asio) type driver. The next best is a Direct X type driver. These drivers came with my sound card which is an M Audio Audiophile 2496 (very good card for the money $136). I have virtually no latency with this card. To find out what driver you are using in Cubase go to "Device Setup" then "VST Multitrack".
Also you might want to check that the track you are recording onto is not delayed. Under the "Inspector" there is a place where you can adjust the track delay in milliseconds, you could always go back and adjust this afterward to make your guitar track lineup with the backup.
Hope this helps.
G
guitvai1 is offline
audio audiophile , audio delta , backing track , ibanez jem
Another Beginner derrickm All Other Guitars (including Prestige) 20 02-15-2007 09:14 AM
Beginner problem PlanetWaves Tech: Setup, Repairs and Mods 20 10-11-2004 02:03 PM
Cubase problem John Gear, Equipment, Recording & Off Topic 2 03-13-2003 12:45 PM
BR8 to Cubase - Having trouble recording BR8 to Cubase MikeyJ Gear, Equipment, Recording & Off Topic 4 02-28-2002 07:01 PM
Jem 555 for a beginner - Good beginner's guitar? kylemac Ibanez JEM, UV, JS & Other Signature Models 17 07-30-2001 01:31 AM
