Behringer FCB1010 Analog Switches - Jemsite
post #1 of 2 (permalink) Old 08-17-2010, 01:24 AM Thread Starter
NSR
Can anyone tell me if I can use the Behringer FCB1010 to switch between the 4 channels of a pre-midi Carvin Quad-X? I believe the channel switching on the Quad-X is latching which is so far compatible with the FCB1010.
I currently have a TC-Electronic G-System that does this. However, I'm looking to upgrade from the G-System and require this functionality elsewhere.
If the FCB1010 is not capable of this, can anyone recommend a similar type of floor controller that does provide this functionality?
Thanks
NSR is offline
post #2 of 2 (permalink) Old 08-17-2010, 06:29 AM Thread Starter
NSR
Re: Behringer FCB1010 Analog Switches
Ok it seems that although the FCB1010 has two outputs for amp control and such with each output taking either a mono or stereo connector. However, it seems that it is only able to use one switch if a stereo connector is used rendering the other disabled. Correct me if I'm wrong as this would possibly be an ideal solution with a tight budget.
I've been doing lots of looking around and so far have come up with these options:
1. Nobels MF2
Possibly looking like the best alternative but looks like they've been discontinued for some time. Anybody know better?
2. G-Labs GSC-2 / GSC-3
Will also do the job but is total overkill. I just want decent MIDI control and 4-channel amp switching functionality. The routing for an audio signal through the loop options would be completely redundant. These units don't seem too common either looking like they're a Polish company retailing through a well known German retailer.
3. Voodoo Lab Control Switcher
Half of the solution at a considerable price. Would still require MIDI foot controller to use the Control Switcher and switch presets on rack systems.
Still looking for suggestions / options if anyone has anything to offer.
NSR is offline
behringer fcb1010 switch
WTB: Behringer FCB1010 (UK) pawel Classified Ads: Guitars and Gear 4 11-30-2007 05:25 PM
FS: PODxt + Behringer FCB1010 JoshIsNumber3 Classified Ads: Guitars and Gear 2 10-11-2006 05:42 PM
Pod XT & Behringer FCB1010 sam_at2001 Gear, Equipment, Recording & Off Topic 2 02-12-2005 01:19 AM
G-Major and Behringer FCB1010 -- How the hell? JiMoSiTY Tech: Setup, Repairs and Mods 3 08-11-2003 09:38 PM
G-Major and Behringer FCB1010 - HELP! JiMoSiTY Gear, Equipment, Recording & Off Topic 5 08-08-2003 05:58 AM
