Behringer V-AMP Pro - Jemsite
post #1 of 17 (permalink) Old 07-29-2006, 11:51 PM Thread Starter
Behringer V-AMP Pro
Can this be used as a "head" and run directly to a cab? I really want to get it but if can't do that then it's not for me. If I recall correctly, in one of JimmyJ's pickup videos, he was using the V-AMP Pro through a Marshall cab, but i'm not absolutely sure.
sirbrandon101 is offline
post #2 of 17 (permalink) Old 07-29-2006, 11:57 PM
Re: Behringer V-AMP Pro
you will need some form of a amplifier to process it.
V-Amp pro is just a processor it has no power on its own, it needs to be amplified
so you could but it would be like this
Vamp > Amplifier > Cabinet
ibanezcollector is offline
post #3 of 17 (permalink) Old 07-30-2006, 12:04 AM Thread Starter
Thanks ibanezcollector. I looked around a bit and wasn't able to find anything on that so I figured I might as well ask here. Guess it's time to find an amp first though.
post #4 of 17 (permalink) Old 07-30-2006, 12:07 AM
You can always get the LX1200. Im pretty sure that's the amplifier version. Its just the V-Amp Pro with a 60WX2 power amp section.
Mr.WizardNeck is offline
post #5 of 17 (permalink) Old 07-30-2006, 09:32 AM
Reviews: 6
Checkout the Carvin DCM150 or the Rocktron Velocity 120/100. Both cost about the same as a V-AMP PRO so you'd be into a comple rack rig for only $300 or so.
Robotechnology is offline
post #6 of 17 (permalink) Old 07-30-2006, 10:03 AM Thread Starter
So I would be able to run the V-Amp with a power amp and then send it to a cab? If so, that would be exactly what i'm looking for. Thanks robo.
post #7 of 17 (permalink) Old 07-30-2006, 10:07 AM
Someone here once posted a rig that had a V-amp Pro, into a 1200 watt Behringer power amp into two 4 12 cabs.
Rotti is offline
post #8 of 17 (permalink) Old 07-30-2006, 12:08 PM
Also get a tube mic pre. Nothing brings out the sounds of my Behringer modelers like my Behringer Mic100. It livens everything up and makes everything seem so...natural. I love it.
post #9 of 17 (permalink) Old 07-30-2006, 01:46 PM
Dee
How does that work, guitar --> MIC100 --> V-AMP (or other modeller)?
Dee is offline
post #10 of 17 (permalink) Old 07-30-2006, 01:53 PM
hey all
that was me with that pic
i had the Behringer EP2500 2x1200 watt power amp
then i later got a rack case for it
be warned, the ep2500 is really really heavy, and make sure you disable the speaker sim on the vamp pro, let the tones really come out.
Jim
JimmyJ is offline
post #11 of 17 (permalink) Old 07-30-2006, 01:59 PM
Jim, did you have any problems with the EP2500 being noisy at all? Because I just wondered if it was a fan-based power amp or not, as the fans would be blowing.
the.godfather is offline
post #12 of 17 (permalink) Old 07-30-2006, 02:17 PM
Yup. Just have the volume low on the mic thing and turn the tube gain up about 50-75% of the way.
post #13 of 17 (permalink) Old 07-30-2006, 02:44 PM
How the heck do those cabs handle 1200 watts?
Lefty Robb is offline
post #14 of 17 (permalink) Old 07-30-2006, 02:54 PM
Dee
Cool, I'll look into it.
Dee is offline
post #15 of 17 (permalink) Old 07-30-2006, 05:44 PM
i dunno how they handle it but they do, they are 400watt rms cabs tho,
as for the fan, at quiet levels (almost headphone volume) you can hear it, apart from that, quiet as a mouse really.
JimmyJ is offline
power amp , power amps , rocktron velocity
Behringer direct boxes -- anybody tried 'em? bduersch Gear, Equipment, Recording & Off Topic 4 10-31-2005 11:14 AM
FS:RG1570 - 2 Months old w/UV1000, Behringer GM10 and x-vamp lhrocker Classified Ads: Guitars and Gear 4 04-18-2005 04:36 PM
Carvin Legacy head through this cab....(behringer) ChrisB95678 Gear, Equipment, Recording & Off Topic 21 12-15-2003 06:44 PM
G-Major and Behringer FCB1010 -- How the hell? JiMoSiTY Tech: Setup, Repairs and Mods 3 08-11-2003 09:38 PM
G-Major and Behringer FCB1010 - HELP! JiMoSiTY Gear, Equipment, Recording & Off Topic 5 08-08-2003 05:58 AM
