Best way to clean EMG's? - Jemsite
post #1 of 6 (permalink) Old 10-16-2005, 04:12 PM Thread Starter
Reviews: 7
I was just restinging my first guitar with EMG's on it and I noticed that the Pick-ups show the same build up of dirt that I usually see on the fretboard around the first 3 or four frets right under the strings. I wanted to know the best way to clean that off the pick-ups without damaging them. Thanks in advance!
brothersnowgone is offline
post #2 of 6 (permalink) Old 10-16-2005, 08:16 PM
Re: Best way to clean EMG's?
Are they black? If so I'd use Naptha. If you don't have that, use rubbing alcohol. If they're white I'd say use a little bit of toothpaste and a toothbrush. But anything that cuts grease is fine, like Windex. If you use something like a furniture wax or polish it can shine them up.
frankfalbo is offline
post #3 of 6 (permalink) Old 10-16-2005, 08:32 PM
One word... "spit"..
buddroyce is offline
post #4 of 6 (permalink) Old 10-16-2005, 09:01 PM
Spit works just as well as anything else, I guess. I generally use rubbing alcohol myself.
lyconxero is offline
post #5 of 6 (permalink) Old 10-16-2005, 10:06 PM Thread Starter
Reviews: 7
It's good to know I can clean it off, at first I thought they were permanently stained. Thanks for the help everyone!
post #6 of 6 (permalink) Old 10-17-2005, 07:02 AM
i thought emgs had a solid plastic cover. seems like you should just get a damp cloth and wipe it down
adamcbest is offline
OCD on JSX Clean Darin Gear, Equipment, Recording & Off Topic 20 11-16-2008 01:08 PM
clean up spkenn5 Pickups & wiring 7 01-25-2007 08:51 AM
I need to clean up some mud. Given to Fly All Other Guitars (including Prestige) 5 03-28-2004 11:27 AM
Clean Up Your Act! Kevan Gear, Equipment, Recording & Off Topic 5 05-09-2002 07:22 PM
Best small clean practice amp - Solid state, good clean tone Kremlin Gear, Equipment, Recording & Off Topic 9 04-09-2002 11:03 PM
