A better sound card / audio interface - Jemsite
post #1 of 6 (permalink) Old 09-09-2010, 07:09 PM Thread Starter
Hey guys!
I'm using a POD X3 live for recording my guitar and it acts on its own as a decent enough audio interface! I mostly jam along with the POD and use my laptop's headphone's output into the POD's CD/MP3 input to have my backing track playing along and the whole mix comes out from my cans plugged into the POD.
However the POD also provides a soundcard driver via USB, with In and Out functions.
I just found out that the backing track sounds noticeably worse than if I stream it to the POD via the USB "soundcard" it provides to my laptop. But the POD has a known fault with the USB soundcard drivers so I cannot use this.... (cuts off more often than not)
I wonder what would be a decent and not too expensive soundcard / audio interface that I could get to replace my laptop's soundcard standard headphone's out ? And maybe thinking ahead for future usage too
Thanks for your time!
mindwalker is offline
post #2 of 6 (permalink) Old 09-10-2010, 02:38 AM
axemanrio's Avatar
Re: A better sound card / audio interface
I've had the M-Audio Firewire Solo for over a year and haven't found a reason to switch. Unless I need more than 2 simultaneous tracks, I won't need another - it works well, was easy to set up and plugs right into REAPER with no issues.
There's a less expensive M-Audio Fast Track that you may want to check out too.
axemanrio is offline
post #3 of 6 (permalink) Old 09-10-2010, 12:27 PM
it depends on how much you want spending, and how many inputs and outputs you be needing.
the PreSonus Audio Box USB cost around 150 USD an seems very nice for a simple but complete audio interface.
Focusrite also have some good offering so does M-Audio
_FR0D0 is offline
post #4 of 6 (permalink) Old 09-10-2010, 01:14 PM Thread Starter
Isn't the Presonus Audio Box and the M-Audio Fast Track USB 1.1 ? I'm running at the moment a laptop with a 5k rpm and I'm a bit afraid that there can be hiccups even recording just one instrument at a time...
However there's not so many "budget" USB 2.0 audio interfaces... the EMU 0404 from what I read on the net seems to be the best and not too expensive. The M-Audio Fast Track Ultra is USB 2.0 but I don't think I need so many mic ins as it offers. And there's other cheap USB 2.0 offers from Tascam but the word out on the net is that there's huge problems with the drivers...
post #5 of 6 (permalink) Old 09-10-2010, 09:35 PM
For the number of ins and outs that the PreSonus Audio Box USB have the usb 1.1 spec is enough, but your slow Hard Disk could be a problem (and one that USB 2.0 will not solve at all).
So for any serious work with your laptop you getting a 7200 RPM storage drive is highly recommended.
_FR0D0 is offline
post #6 of 6 (permalink) Old 09-28-2010, 08:29 AM
The Lexicon desktop USB cards are pretty cool and work well, not just saing that because i work for Lexicon :-) check out the I-ONIX U22. Looks neat too...
xammy-b is offline
audio interface , sound card
FS M-Audio Delta 1010 sound card velocity Classified Ads: Guitars and Gear 0 11-18-2009 02:15 PM
Connecting M-Audio sound card to AV amp.. Ibanezer_hi Gear, Equipment, Recording & Off Topic 1 02-23-2009 04:02 PM
FS: Shure SM57, M-Audio DMP3, Tascam US-122L USB Audio interface(package), GuitarEvan07 Classified Ads: Guitars and Gear 6 01-16-2009 07:17 PM
M-Audio Sound Card? Darren Wonnacott Gear, Equipment, Recording & Off Topic 8 02-27-2006 08:44 PM
Audio Card Infinite Gear, Equipment, Recording & Off Topic 6 07-24-2005 10:48 AM
