Bose 802/302 System - Advice? - Jemsite
post #1 of 3 (permalink) Old 07-26-2003, 10:23 AM Thread Starter
Hi,
I have a set of Bose 802 speakers which kinda belong to my singer. I just replaced the surrounds for him, and used them at a DJ set on Friday, with a mono Peavey powered mixer.
Having never used them for anything but vocals before, the fact this amp wasn't stereo never got noticed. However now I perceive its a problem and want to upgrade, not only the amp, but to add a set of the 302 bass bins as well.
So I took a look at the crossover/controller box. It says the input from your mixing source feeds into it, then you get 4 outputs to the 2 302s, and 2 802s, L & R each. These go to amps, then speakers, its called Biamplified mode.
So does this mean I need a 4-channel power amp to go with it. In which case, can anybody recommend one?
I already have a mixing desk, so I don't need the mixer section of the Peavey anyway, right?
Thanks in advance,
Jamie
Jamie is offline
post #2 of 3 (permalink) Old 07-26-2003, 03:03 PM
Re: Bose 802/302 System - Advice?
Originally Posted by Jamie
Hi,
Thanks in advance,
Jamie
I recommend 2 stereo power amps instead of a 4 channel. That way you can maximise your flexibility and probably more likely to get a good deal on used stuff. The sub amp should be higher power than the 802s. I use a 250w/ch for my cabs and a 400w/ch for my subs (or something like that). Got it all used.
JESTER700 is offline
post #3 of 3 (permalink) Old 07-26-2003, 06:30 PM Thread Starter
Thats just what I was looking for, cheers mate, lock it up!
Jamie is offline
power amp , power amps
PA System advice mike570 Off-topic / Miscellaneous 6 02-11-2010 08:29 AM
Bose suspension Rotti Off-topic / Miscellaneous 0 03-06-2007 11:13 PM
Bose Headphones Two hands31 Gear, Equipment, Recording & Off Topic 10 08-12-2004 11:14 AM
Anybody experience the Bose PAS yet? Gresh Gear, Equipment, Recording & Off Topic 21 07-30-2004 01:55 PM
