Buying a GT-6 , need some help - Jemsite
post #1 of 4 (permalink) Old 06-22-2006, 02:56 PM Thread Starter
Mostly about the expression pedal...will it control how much gain i have?
AKA Tender Surrender style...I just thought of it after I got home, so didn't see if I could at the store.
Ozzdoc is offline
post #2 of 4 (permalink) Old 06-29-2006, 10:38 PM
Re: Buying a GT-6 , need some help
I'm "pretty" sure you can. Im at work now but when i get home ill check it and let u know for sure.
Iceman24 is offline
post #3 of 4 (permalink) Old 06-29-2006, 10:56 PM
rgr
IIRC, you can assign it to pretty much any parameter. The problem with assigning it to gain may be that volume will also change.
rgr is offline
post #4 of 4 (permalink) Old 06-30-2006, 02:19 PM
Gex
Vai just turns down the volume on his guitar.
It will work on any amp pretty well if you have a hi-pass filter on your pot.
Gex is offline
expression pedal
Ibanez JEM555? Is it worth it? - buying a JEM55, and need fe johnjohn969 Ibanez JEM, UV, JS & Other Signature Models 9 09-11-2013 09:16 AM
Trying and buying j custom ibanez ashton All Other Guitars (including Prestige) 23 06-13-2006 06:24 PM
Help! Thinking About Buying An Explorer Knock-Off! Big Red All Other Guitars (including Prestige) 15 03-21-2006 12:47 PM
buying a js marshall Ibanez JEM, UV, JS & Other Signature Models 11 11-22-2003 12:56 PM
B.C. Rich NJ Jr.V with widow headstock. - I AM buying one of MorbidAngel All Other Guitars (including Prestige) 12 04-05-2002 09:24 AM
