Cab question. - Jemsite
post #1 of 11 (permalink) Old 09-07-2010, 04:43 PM Thread Starter
Cab question.
Ok, now this may sound like a stupid question but i can't help but ask.
Soon i'll be aquring a JCM 800 cab, and i want to know if i can plug my 15 watt line 6 spider into it through the headphone jack, i know the answer is probably a no but it's worth asking.
thanks.
mystro is offline
post #2 of 11 (permalink) Old 09-07-2010, 05:00 PM
jemaholic's Avatar
Re: Cab question.
Well, if your 800 cab is a 4x12 then it's a 16 ohm load mono input. I doubt your Line 6 has a matched output. Mismatched ohm loads can damage your amp....
jemaholic is offline
post #3 of 11 (permalink) Old 09-07-2010, 05:01 PM Thread Starter
Re: Cab question.
I'm pretty sure my amp is 4 ohms, so i'm guessing that is a definet no...
thanks.
mystro is offline
post #4 of 11 (permalink) Old 09-07-2010, 06:51 PM
Reviews: 98
Re: Cab question.
The headphone outs on most electronics, especially amps, are not direct line outs--they are compensated for lower levels. Whay you could do, and this will require just a basic knowledge of electronics/wiring, is to ad your own speaker output. To do this, take the two wire off of the Line Y speaker, splice in another two leads with a 1/4" phone jack female end. Then hook the original speaker leads back into the Line 6 speaker and you have the new plug dangling from the leads. Run a 1/4" instrument/speaker cable from that to your Marshall cab. Now you'll get sound from the Spider AND the Marshall.
AlaskaBat is offline
post #5 of 11 (permalink) Old 09-07-2010, 08:14 PM
jemaholic's Avatar
Re: Cab question.
Might work Bat, but a single speaker usually carries an 8 ohm load- still have the mismatch.
My suggestion is to go to a local electrical tech and have him set up a 16 ohm output jack from the amp - then your matched impedance will make that Marshall scream.
post #6 of 11 (permalink) Old 09-07-2010, 08:18 PM
Reviews: 98
Re: Cab question.
Yeah--the impedance would be the big issue.
post #7 of 11 (permalink) Old 09-07-2010, 08:19 PM
Re: Cab question.
i don't think you can do that. Thats adding another speaker parallel to the one which is there probably lowers the resistance ,if i remember right, and may damage the amp.
Ibanized is offline
post #8 of 11 (permalink) Old 09-07-2010, 08:23 PM
Reviews: 98
Re: Cab question.
That's what we're talking about--the impedance is the problem, unless he can get the amp modded for the load.
post #9 of 11 (permalink) Old 09-07-2010, 08:29 PM
Re: Cab question.
i know nothing about line 6 amps but most amps i have seen you can just unplug the original speaker , and plug in the cab. Maybe the load is switchable on the amps back. Than the amp just powers the cab, and the internal speaker is off.
Ibanized is offline
post #10 of 11 (permalink) Old 09-07-2010, 09:55 PM
Reviews: 98
Re: Cab question.
No--when you "unplug" the original speaker, you just have the two leads, not a phono plug to insert into a cab.
post #11 of 11 (permalink) Old 09-08-2010, 06:33 PM Thread Starter
Re: Cab question.
Ok then new idea, I'm not sure which cab it is, so it could ither have 8 ohm or 16 ohm speakers, i've heard 16 ohm 4x12's can be wired to 4, 16, and 64ohms. if that's the case i can wire it to 4 ohms and it will be matched....would that work?
mystro is offline
cab
f-space question, and pickup combination question Jing Tech: Setup, Repairs and Mods 14 05-03-2006 02:50 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 07:06 AM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 02:41 PM
Bad horsie 2 question and Amp Question snorkthesick Gear, Equipment, Recording & Off Topic 1 04-11-2004 04:56 PM
BSB Question - neck finish question j i m Ibanez JEM, UV, JS & Other Signature Models 7 02-23-2001 05:29 PM
