Cabs... Help :P! - Jemsite
post #1 of 5 (permalink) Old 07-31-2008, 11:29 AM Thread Starter
Reviews: 20
Cabs... Help :P!
Hi all, Hope all is well. I'm just wondering what woods are good for Cab construction? Also, if possible could you explain what makes a cab good or bad, or properties of a certain type of construction (e.g. Open back/Closed back) if you get me?
Thanks
Best Regards
Jonny
Guitarist-Jonny is offline
post #2 of 5 (permalink) Old 07-31-2008, 07:08 PM
Reviews: 7
Re: Cabs... Help :P!
Materials range from a lot of different solid woods, to plywood (mostly birch, but I've gone cheap before and used spare pine plywood for really cheap budget cabs). Constuction is as simple as you want it to be. Basically a box with sufficient bracing. I usually build a cab strong enough for me to sit on it and it not make a peep (I weigh like 150lbs). Open vs. closed back is all about preference. I like a closed back 4x12 w/ a open back 2x12 on top
There should be plenty of sites with tons of info if you search "guitar cab construction" on google or something. They will all pretty much get the same points across...
brothersnowgone is offline
post #3 of 5 (permalink) Old 07-31-2008, 08:10 PM Thread Starter
Reviews: 20
I checked it out, I'm not sure :S I can't find a decent site ! Would you say, in a cab, you pay for the construction quality and speakers it comes with rather than the woods used?
Thanks
Regards
Jonny
post #4 of 5 (permalink) Old 08-01-2008, 06:05 AM
Reviews: 7
You got the basic idea. Although a birch ply cab will probably sound a bit more defined and crisp then say a cheaper pine ply cab. But any good thickness, strong material can be used to make a modern cab and sound pretty good. All that really matters is no joint's vibrating, and nothing rattle's what-so-ever.
post #5 of 5 (permalink) Old 08-01-2008, 08:00 AM Thread Starter
Reviews: 20
So its as simple as that? Wow, I thought there must be more to it than that giving the prices of some cabs out there in comparison to others- amazing! Thanks Brothersnowgone !
All the best
Regards
Jonny
Two cabs kpinks Gear, Equipment, Recording & Off Topic 2 09-10-2007 08:25 PM
Neodymium cabs? Roland Gear, Equipment, Recording & Off Topic 4 06-18-2007 05:55 PM
New cabs! TheOrangeChannel Gear, Equipment, Recording & Off Topic 1 02-19-2005 12:12 AM
More than 2 cabs? Globbits Gear, Equipment, Recording & Off Topic 1 05-02-2003 08:09 PM
AVATAR CABS Shredhead777 Gear, Equipment, Recording & Off Topic 4 11-28-2002 05:09 AM
