Can't Record!!! HELP!!! - Jemsite
post #1 of 4 (permalink) Old 08-11-2002, 03:44 AM Thread Starter
Help me guys! I've been doing everything good but can't do it! I'm trying to run my Line 6 Flextone II direct to my computer (PIII 800 with 512 megs of ram and a SBLive! Value card) I run the Send plug in the back to the Line in (there is 2 I tried 1 then the 2nd then a y split to both). I get no sound what-so-ever to record with that. So I looked at all my sound card settings. I have all the settings correct. Nothing is muted, everything works. Any suggestions? pointers? walk-through's? I'm smart with computers but this one is a mellon scratcher!
RSVampire is offline
post #2 of 4 (permalink) Old 08-11-2002, 06:59 AM
Did you ever click onto the sound icon? Go there and click on options and then properties. 'Adjust volume for recording'....then hit 'OK.'
I don't know if you did that but it could easily have been overlooked.
Carlo is offline
post #3 of 4 (permalink) Old 08-11-2002, 03:40 PM Thread Starter
yes I did. Like I said I have all my sound card settings correct. Nothing is muted or turned down. The recording parts should all be working. But it isn't...
post #4 of 4 (permalink) Old 08-15-2002, 02:32 AM
Are you running the line out of your amp.. Into the microphone jack on your PC?
If so, perhaps it's an impedance problem?
Plug a set of headphones into the jack that you're running TO the PC, and see if you get sound. If not - that's the problem - try using the headphone jack (if there is one) instead. Otherwise you'll need either some sort of converter, or better yet a "real" soundcard IN for your PC.
M-Audio makes tons of great stuff. Some swear by the Audiophile line, while I use the preouts on my GSP2101 to an M-Audio Delta-44 breakout box.
Give me a little more info on your actual setup and I'll see if I can figure it out.
- CQ7
CQ7String is offline
audio delta
NRD - R Stands for Record ;) IbanezFreak777 Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 7 07-31-2011 06:06 AM
Just record something mi2tom Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 09-15-2010 10:23 AM
How NOT to record Josh_P Off-topic / Miscellaneous 2 03-22-2007 10:42 PM
what to record with? Mister CCJ Gear, Equipment, Recording & Off Topic 0 06-08-2006 01:06 PM
WE SHOULD RECORD SOMETHING - WE SHOULD RECORD SOMETHING shredmaster Ibanez JEM, UV, JS & Other Signature Models 1 07-26-2001 08:00 PM
