Carvin Legacy - Jemsite
post #1 of 4 (permalink) Old 07-13-2010, 12:40 PM Thread Starter
Carvin Legacy
I am trying to decide wether or not to buy a Carvin Legacy 2 head and cab. The problem is I do not gig and would only use it for bedroom playing (at the moment!) Would I be able to use it at low volumes and not upset the neighbours . The deal is a good one but the volume issue could sway it for me. I currently have a Line 6 Flextone 2 amp but would dearly like to play a valve amp. Any ideas?
ANT5150 is offline
post #2 of 4 (permalink) Old 07-13-2010, 02:48 PM
Reviews: 59
Re: Carvin Legacy
I think it depends on if you're going to ever gig out with it. If it's a really good deal, then you might as well go for it. If it doesn't work out, you can always sell it. If you don't have any aspirations of gigging with it, or you're worried that you might not be able to make your money back when selling, I might think twice since it's a lot of amp for bedroom playing and there are more reasonable valve offerings.
As for tone/volume, the master volume does a good job. It's certainly better than the first legacy for playing quiet but tube amps and the way we perceive their sounds are better when you can get the volume up a bit. How quiet do you need it to be at home? I thought it got a little thin when trying to keep it to conversation volumes and lower.
smooth55 is offline
post #3 of 4 (permalink) Old 07-13-2010, 05:54 PM
Re: Carvin Legacy
are you not able to try it before buying it? if not, i would say you may be disappointed in the tone at bedroom levels. every tube amp i've owned has sounded much better when you can push the power tubes, including my little 5 watt blackstar. keep in mind bedroom volume for a 50 - 100w tube amp is typically around 1 - 2
rastachild is offline
post #4 of 4 (permalink) Old 07-23-2010, 09:20 AM
Re: Carvin Legacy
The Legacy 2 (and 1, for that matter) sound great at a bedroom volume. The volume on the Legacy 1 is jumpy, but the 2 has a master volume, so you won't run into that. Unless you're looking for power tube distortion, low volumes are fine (for tube amps.) An amp like the legacy gets its tone from preamp distortion, so you'll be fine. Since most players get their gain from either a preamp, or a pedal, the whole idea of 'turning an amp up,' isn't as practical as if you're using an old marshall or fender. Yes, you will get sag, and it will sound good, or better at a high volume.. But no, you don't need to crank most modern amps in order to make them sound good. The reason Marshalls and Recto's sound horrible at a bedroom volume, is because of the buzzy high frequencies. In the mix a band, they cut through, and sound great. In your bedroom, they sound terrible. Not much to do with volume, in my opinion.
shogun is offline
Carvin Legacy 2 Amp. ANT5150 Gear, Equipment, Recording & Off Topic 9 03-02-2010 02:07 PM
WTB Carvin Legacy TRIDS Classified Ads: Guitars and Gear 0 09-10-2007 02:12 PM
WTB: CARVIN LEGACY! UK! twooos Classified Ads: Guitars and Gear 0 09-09-2007 04:23 PM
Where can I buy Carvin Legacy amp??? robbiedp Gear, Equipment, Recording & Off Topic 6 04-05-2005 12:31 PM
