Carvin Legacy 3 Thoughts..? - Jemsite
 1Likes
  • 1 Post By blkspade
post #1 of 3 (permalink) Old 05-04-2018, 09:28 PM Thread Starter
Might be pulling the trigger on a Carvin Legacy 3 Head. Any thoughts from those who own one would be greatly appreciated..! Many thanks in advance..!
dougatp is offline
post #2 of 3 (permalink) Old 05-04-2018, 09:39 PM
Re: Carvin Legacy 3 Thoughts..?
Great clean channel but good luck getting any clarity on the overdrive channels. The gain channels are very dependent on the presence setting, which is very hard to tame. It goes from very dark to way too bright without much in between.
Great amp and features on paper - I had one and worked with it for a while. Had the midi hooked up and all but could not dial in a high gain tone with clarity no matter what.
Great cleans though!
startled is offline
post #3 of 3 (permalink) Old 05-28-2018, 03:04 PM
I think its a great amp for the price and its incredibly versatile. The master volume does work as Vai describes, along with having 3 output levels. I use mine with the older 100watt Green Back legacy cabinet, so generally keep the amp at the 50watt setting. Recorded this on it.
Gear:
RG 2550 w/ evo2 breed neck
SZ520 paf pro neck stock bridge
RG920 Premium
Jem7V-WH
Marshall Haze 15
blkspade is offline
About the Carvin Legacy III. Thoughts? blkspade Gear, Equipment, Recording & Off Topic 26 10-16-2016 04:53 PM
FS: Carvin Legacy 3 keg Classified Ads: Guitars and Gear 0 10-18-2015 09:43 PM
Carvin Legacy Swirled777 Classified Ads: Guitars and Gear 1 02-14-2012 11:30 PM
Carvin Legacy????? maestrocity91 Gear, Equipment, Recording & Off Topic 14 03-09-2007 06:46 PM
WTT: Carvin Legacy head + Cash for Carvin V3 head AKMG Classified Ads: Guitars and Gear 0 10-03-2006 10:52 PM
