Carvin Legacy Effects Loops - Jemsite
post #1 of 6 (permalink) Old 06-30-2010, 01:48 PM Thread Starter
Carvin Legacy Effects Loops problem HELP
Hello everyone.
I own a Carvin Legacy Head with 2x12 Cab.
i love it, the sound is what im looking for.
the thing is though the effects loop is bleeding a dry signal.
i called carvin and they said i had something wrong with my amp. so i went and tried another legacy, and the same thing.
i have the volume pedal hooked as last in the effects loops before the return.
when i lift it up, all the other effects such as delay, mods, aren't heard, but the dry signal is there. the sound is low, yet still noticeable.
i tried everything from changing to mogami cables, to trying different power outlets. nothing worked.
i live in Boston, and all the amp techs said that a mod for that would cost me around $400.
What are my choices here?
i was thinking if there is like an external device that u can hook up to the effects loops to become 100% series effects loop? i really love the sound of the amp, and i really dont want to get rid of it for something like that...
Last edited by samhamade; 06-30-2010 at 01:51 PM. Reason: forgot to mention the word "problem"
samhamade is offline
post #2 of 6 (permalink) Old 06-30-2010, 03:49 PM
Contributor
Cornbread's Avatar
Re: Carvin Legacy Effects Loops
volume pedal needs to be out of the loop. i had the same issue. i also noticed a much better sound if only time based effects are in the loop. don't ask me why but as soon as i left my chorus and delay in the loop and moved my other effects out it got much better. volume pedal is now the last thing before the input on my amp. chours delay flanger is now in the loop
Cornbread is offline
post #3 of 6 (permalink) Old 06-30-2010, 07:03 PM Thread Starter
the reason i have the volume pedal at the end is because i prefer the volume pedal to act like a master volume...
Cornbread, do u also own a legacy?
post #4 of 6 (permalink) Old 07-01-2010, 02:12 PM
Contributor
Cornbread's Avatar
yes i have the vl212 combo.
when only time based effects in the loop and volume last before the input i get great sound. the nice part is the volume still works like it should but doesn't cut off any echo or delay effects. they still trail off like normal.
not saying it is the end all but give it a try and see what you think. let me know
post #5 of 6 (permalink) Old 07-01-2010, 03:24 PM Thread Starter
the thing is that i have a TC electronic G system hooked up through 4 cable method system.
thats why i dont have the freedom to do that.
i just wish that the effects loops were 100% series.
i dont know...
post #6 of 6 (permalink) Old 07-01-2010, 03:45 PM
Contributor
Cornbread's Avatar
ok 4 cable method. i havent run into that yet. have a axefx comming so i might get some experience with that
carvin legacy
Carvin Legacy Guitarmiester Classified Ads: Guitars and Gear 5 04-04-2008 01:32 PM
Single Effects Set up Run through Two Loops...Possible? Gresh Gear, Equipment, Recording & Off Topic 4 12-11-2003 01:01 PM
Effects Loops Frankie Gear, Equipment, Recording & Off Topic 1 10-18-2002 08:18 AM
pedals and effects loops tsmith Gear, Equipment, Recording & Off Topic 5 03-04-2001 07:41 PM
Parallel Effects Loops - different levels of effect on diffe luther Gear, Equipment, Recording & Off Topic 6 12-31-2000 05:22 PM
