Celestion speaker question ?????? - Jemsite
post #1 of 10 (permalink) Old 04-01-2003, 02:35 AM Thread Starter
What is the difference between the Celestion G12-50 and the G12T-75?
I have G12-50 speakers in my 4x12 cab and I keep hearing good things about the G12T-75 is there a big difference between the two?
wireman24 is offline
post #2 of 10 (permalink) Old 04-01-2003, 06:47 AM
i think 50s are 50watt speakers, and '75' means 75watt. and '12' means 12 inches.
i think...
nuno is offline
post #3 of 10 (permalink) Old 04-01-2003, 01:34 PM
I THINK Nuno is correct but I'm not sure. The reason is that there is the famous Celestion Vintage 30 but it's 70 watts. Ultimately speakers are like pickups (but a little easier) in the way that they are difficult to predict the exact result you are going to get until you actually try them. However, it may be easier to find similarly constructed cabs from a manufacturer where the only difference is the model of speakers. This will give you some sort of reference.
Mike 777 Haug
mike777 is offline
post #4 of 10 (permalink) Old 04-02-2003, 08:44 AM
There's a G12T-75 Sidewinder model with 150 watts.
LGMT is offline
post #5 of 10 (permalink) Old 04-02-2003, 09:54 AM
...oops!
nuno is offline
post #6 of 10 (permalink) Old 04-03-2003, 03:34 AM
ScottB's Avatar
The standard Marshall 1960 A & B cabinets from the JCM800, 900 & 2000 series use the G12-L75 watt speakers.
The 1960AX & BX use the 25 watt Greenbacks.
The 1960AV & BV use the 60 watt Vintage 30s.
I've never opened one up to be certain of the speaker model, but the AVT / Valvestate 4x12 cabinets are loaded with 50 watt Celestions.
ScottB is offline
post #7 of 10 (permalink) Old 04-03-2003, 03:49 AM
My JCM800 1960A and JCM900 1960B have G12T-75's.
CrossingStar is offline
post #8 of 10 (permalink) Old 04-03-2003, 04:28 AM
ok, but the question was: "What is the difference between the Celestion G12-50 and the G12T-75?"...
nuno is offline
post #9 of 10 (permalink) Old 04-03-2003, 01:33 PM
Check out http://www.celestion.com/pro/pro.htm
<snip>
G12T-75
Extremely versatile loudspeaker, found in many of the world's leading guitar amplifiers - the best-selling guitar speaker of all time
• Wide frequency response and high sensitivity
• Suited to all musical styles, but excels in Rock, Metal, Thrash and high-gain Indie
• Especially suited with multi-effect units and rack systems
Power Handling 75W
Impedance 8 / 16 Ohm
Sensitivity (1W @ 1m) 97dB
Resonant Frequency 75Hz
Frequency Response 75Hz - 5kHz
Magnet Weight 35oz
G12E-50
Celestion's General Series of guitar loudspeakers is designed to suit all modern playing styles. Pop and Rock players will love the tight and punchy sound of the G12 Series, while Blues guitarists will revel in the warmth and resonance of the Vintage 8 and Vintage 10. Each is carefully manufactured using the finest materials, from the magnet down to the voice coil, to produce a sound that’s both tight and dynamic. Whether you’re recreating a stadium-sized stack or simply upgrading the speaker in your bedroom practice amp, these Celestion loudspeakers offer quality, tone and value. Available in 8 or 16 Ohm impedance (G10C-30 is 8 Ohm only).
Power Handling : 50W
Sensitivity (1W @ 1m): 96dB
Resonant Frequency: 90Hz
Frequency Response: 90Hz - 5kHz
Magnet Weight : 17oz
</snip>
SalemB is offline
post #10 of 10 (permalink) Old 04-03-2003, 09:22 PM Thread Starter
Thanks alot that is just what I was looking for
celestion vintage , practice amp , rack system
FS Kustom Tube 12A amp with Celestion speaker $50 xenophon101 Classified Ads: Guitars and Gear 0 07-27-2009 12:51 AM
Best Celestion speaker? Guitarist-Jonny Gear, Equipment, Recording & Off Topic 16 05-29-2009 04:37 AM
Celestion speaker help [email protected] Gear, Equipment, Recording & Off Topic 1 06-18-2008 02:00 AM
speaker question JM5150 Gear, Equipment, Recording & Off Topic 7 06-22-2007 09:59 AM
FS: Modded Peavey Classic 30 w/ Celestion Speaker Spectre518 Classified Ads: Guitars and Gear 0 12-05-2005 08:39 PM
