Cheapest Gig Amp with an Effects Loop - Page 2 - Jemsite
post #16 of 24 (permalink) Old 07-30-2008, 11:52 AM
Re: Cheapest Gig Amp with an Effects Loop
Originally Posted by Valhalla View Post
You don't need 100 watts if you want to get a real tube amp...You could probably find a gently used Peavey Classic 30 for close to what your budget is, and it has a great effects loop and killer tube tone to boot...It's 30 watts, but it is one LOUD mutha****a! All of the knobs go to 12, and it's a great amp for gigging with and will really cut through the mix. Try one out!
I second this suggestion, they had these amps at the place i was studying at and they are really good value for money. I think they would warm up and give you a more dynamic tone and by themselves sound pretty nice. Plus i think they also have their own lead boost built in as well with spring reverb?
dark_void86 is offline
post #17 of 24 (permalink) Old 07-30-2008, 01:07 PM
If you don't mind second hand look for a Fender Hot Rod Deluxe, or as many have already suggested, a Peavey Classic 30. Both work well with digital modellers, sound great on their own and they are loud enough for a local gig. Plus they are not rare, check the bay.
That being said, you really need to get yourself to all the local stores and try as many amps as possible (even the really expensive stuff if they let you).
Rock on!
HeavyMetal4Ever is offline
post #18 of 24 (permalink) Old 07-30-2008, 06:53 PM
you can also look at a peavey bandit 112... 80watts of power... nice for the gt8... i use that combination and its nice....
Ironjose is offline
post #19 of 24 (permalink) Old 07-31-2008, 03:02 AM
Peavey Bandit, Peavey Classic 30, Marshall AVT50... 50 Watts should be plenty for gigging
'87
Shredder87 is offline
post #20 of 24 (permalink) Old 07-31-2008, 11:35 AM
Originally Posted by JKao View Post
Thanks everyone! I'll make sure to check them out But I have a question... How exactly would I plug in my Boss GT-8 into it? Apparently there is a 4-cable method, but it only makes the unit an effects unit and not the total preamp..
Thanks!
Jeffrey
I have a GT-8 which I use with my Laney VH100R
The wiring is like this:
Guitar plugged into GT-8 INPUT.
GT-8 SEND into Laney INPUT
Laney SEND into GT-8 RETURN
GT-8 OUTPUT into Laney RETURN
If you put the effects loop on the GT-8 after the wah/distortion and before the chorus/delay/reverbs, then you have the wah/distortions in front of the amp as usual, the amplifier pre-amp is in the effects loop of the GT-8 and the delay/chorus/reverb is in the effects loop of the amplifier.
Also if you assign a volume pedal after the return of the GT-8 loop you can alter volume without affecting the overdrive, kind of like a master volume!
Your amplifier needs a series effects loop for this to work though.
Jim
Vim Fuego is offline
post #21 of 24 (permalink) Old 07-31-2008, 11:40 AM
Look into the Peavys that have been suggested here. Only big expensive (relatively) solid state amps like a Roland JC120 or a Polytone will do a gig justice with your gt-8. I'm sorry but I have no love what so ever for any Crates.
kotornut is offline
post #22 of 24 (permalink) Old 08-25-2008, 11:03 PM
Originally Posted by mi2tom View Post
To gig you need at least a 100watt, I recommend you the marshall mg100 it goes at around 460usd. Some amp do have an effects loop but they don't have poweramp master volume, and it'll be pain in the arse and you can't hear anything onstage. But however too I recommend not using the effects loop, any amp will sound good if you plug it straight away to the input and tweak your bass, mid and high control from there. It sounded better and it can cut through better than when you plug into an effects loop. I use to do AB comparison with my zoom g9.2tt straight to the input and effects loop and seriously though straight into the input sounded way better.
??? ???? i know guys that gig with 15 watt dr z's
just42dave is offline
post #23 of 24 (permalink) Old 08-26-2008, 06:41 AM
I own the Peavey Valveking 112 and I've tried the Classic 50. Both are 1x12 all-tube amps with more than enough power to blow your head off (I'm literally afraid of, and have yet to go, beyond 6/10 on the volume of the Valveking, it's REALLY loud). The Valveking is better for higher gain tube tone, the Classic 50 for a more classic rock tube crunch. As for the Peavey XXL, I can't comment.
My only recommendation would be to get an all-tube amp for gigging situations, 100w transistor at $400 sounds harsh and not so nice.
varador is offline
post #24 of 24 (permalink) Old 08-26-2008, 07:34 AM
Try the Line 6's...you have so much various sounds for whatever type music you like. the sounds are awsome, and the price is in your range.
560licious is offline
amp settings , loop station , marshall avt , peavey bandit , peavey valveking , peavey xxl , spring reverb , tube tone
Effects loop question... waylay00 Gear, Equipment, Recording & Off Topic 4 01-11-2007 07:43 PM
Effects Loop Help? Jafo Gear, Equipment, Recording & Off Topic 5 05-14-2006 09:10 AM
effects loop w/ pedals? wildealien Gear, Equipment, Recording & Off Topic 19 07-23-2004 11:30 AM
Effects loop squeeling Beavis Gear, Equipment, Recording & Off Topic 3 04-01-2003 01:28 PM
Problems using an effects loop-please help mginty Gear, Equipment, Recording & Off Topic 3 12-06-2001 03:46 PM
