Choosing an EQ for the effects loop - Jemsite
post #1 of 6 (permalink) Old 12-01-2012, 05:35 PM Thread Starter
Hey!
I want to put an EQ into my effects loop and don't know what to buy.
I play anything from traditional metal and hard rock, to thrash and death metal.
I'm using:
JCM 900 Dual Reverb 100w 2x12 combo (please leave out the insults and suggestions of buying a new amp ).
Joyo Vintage Overdrive (like a Bad Monkey, but slightly better imo and even cheaper).
Ibanez XPT700 (with the stock Dimarzio D Activators).
Neon_Knight_ is offline
post #2 of 6 (permalink) Old 12-02-2012, 01:11 AM
Re: Choosing an EQ for the effects loop
Actually i just bought a joyo 6 band eq. Its like an mxr clone and was only 40 bucks. I couldnt be happier with it. Plus the sliders have leds to light tbem up
GUITARMAGEDDON is offline
post #3 of 6 (permalink) Old 12-02-2012, 03:17 AM
Reviews: 15
+1 for the Joyo. I don't own their EQ pedal just yet, but if the quality is anything like the analog delay I have from them, it's an excellent bang for the buck. And it's true bypass!
silverctr is offline
post #4 of 6 (permalink) Old 12-02-2012, 06:30 PM
If you don't mind spending a little more check out the Empress ParaEQ
http://www.empresseffects.com/paraeq.html
guitarnoize is offline
post #5 of 6 (permalink) Old 12-02-2012, 06:42 PM Thread Starter
What makes the Empress ParaEQ worth spending an extra $200? (compared to the Joyo)
post #6 of 6 (permalink) Old 12-02-2012, 07:01 PM
I used to gig with a 900 head,,,and after that , a TSL100 head. I used to run a boss eq in the loop for a solo boost/volume jump, and it did a great job. In fact, I used velcro to attach a little metal bar from the footswitch on the boss eq to the footswitch on a boss dd-5 delay pedal so that one stomp would turn them both on for a volume boost and slight echo/delay at the same time for my leads!
lynchfan6 is offline
effects loop , eq pedal , jcm 900 , xiphos
Effects loop? linuxpenguin Gear, Equipment, Recording & Off Topic 12 09-10-2011 10:23 PM
Need more help choosing an effects pedal Trickae Gear, Equipment, Recording & Off Topic 1 01-18-2011 03:21 PM
choosing an effects setup... djJem Gear, Equipment, Recording & Off Topic 6 04-15-2009 08:02 PM
Effects Loop Set-up johliatay Gear, Equipment, Recording & Off Topic 2 05-13-2008 11:54 AM
Effects Loop Help? Jafo Gear, Equipment, Recording & Off Topic 5 05-14-2006 09:10 AM
