Clean or Overdrive channel - Jemsite
post #1 of 10 (permalink) Old 02-06-2003, 09:20 PM Thread Starter
eg
I have this effects loop jack on my combo amp
How do I use it and with what effects do I use with it.
eg is offline
post #2 of 10 (permalink) Old 02-07-2003, 01:04 AM
Its late and Im tired so you get the abbreviated version...
its pretty simple.
like hooking up your vcr.
Send = out
return = In
incase you didnt know...
it depends on what you are using.
If pedals or rack gear..
but ultimately, just connect them in order of in to out to in to out etc..
start at the out/send and loop all the pedals the same to the in/return..
then with the FX botton on the amps FC will turn on/off the FX signal and you can use the pedals etc..
or if its a rack unit its just 2 cable and te same theory but you have a midi fc to change presets etc...
vwall is offline
post #3 of 10 (permalink) Old 02-07-2003, 05:43 AM
Basically, the effects loop is placed after the preamp stage of your amplifier. Basically, put any effects etc in this loop you want, but generally it'll be the kind of effects you'd normally put after a distortion pedal like chorus, flangers, delay etc (noise gates also )
Hope that makes sense
Effects loops stop everything being very noisy as the effects is after the main amplification stage, so noise won't get amplified as much
James
7 Dying Trees is offline
post #4 of 10 (permalink) Old 02-11-2003, 03:00 AM Thread Starter
eg
Thanks.
One question; do you normally plug the distortion pedal into the clean channel or the overdrive channel on the amp?
Kinda newbie; so I hope you guys don't mind my questions.
Cos I use a DS1 and I find that plugging it into the clean channel just not give just a smooth enough distortion with the amount of sustain that I want.
eg is offline
post #5 of 10 (permalink) Old 02-11-2003, 08:45 AM
I presume your amps only got the one input jack, but 2 channels. keep the DS-1 plugged in, clean channel when you want a clean sound, overdrive amp channel for distortion, and kick in the DS-1 on distortioin channel for a solo boost.
Globbits is offline
post #6 of 10 (permalink) Old 02-11-2003, 09:12 AM
The only effects pedals that don't sound good plugged into an effects loop are distortion and wah-wah.
I usually use my effects loop for delay and reverb (ever try plugging a delay in BEFORE your distortion? Ouch), or if you're after a Dimebag Darrell tone try putting a graphic EQ in your effects loop, followed by noise gate if you have one. Boost the EQ's high and low frequencies and cut the middles.
I prefer to plug phasers, flangers and chorus in the regular stomp-box way, into my amp's distortion channel, but that's personal preference. I don't like the way those three effects sound after distortion, too much like a keyboard or something. I like 'em grungier, Hendrixier.
Ultimately, just plug everything in as many ways as you can think of, because there is no right or wrong, there's only what you like best.
Petie is offline
post #7 of 10 (permalink) Old 02-13-2003, 04:50 AM Thread Starter
eg
Thanks for the inputs; I am asking this cos when I use the overdrive channel and the DS1 at the same time; the sounds become too metallic times... and I don't really know how to balance between distortion and sustain... too little dist. no enough sustain; too much distortion it kills the tone...
I hope you guys get what i'm trying to say here.
Most of all; would like to know how you guys use the DS1 so I can try them out too.
eg is offline
post #8 of 10 (permalink) Old 02-13-2003, 07:37 AM
Like the above posts put the DS1 in front of the preamp, then put your delay, chorus, flange, ect in the loop. If you are not getting enough boost/sustain I remember seeing a thread on this site about a modified DS1 - look it up. Otherwise try a compressor/sustainer as well.
My amp has a tube buffered effects loop (it's a Rivera 55-12) that allows for a simple trick. Connect a 1-foot cord from the "effects out" to the "effects in" jack, turn down the levels for the send and return, turn up your preamp and master volumes. Play around with this until you get the sustain/boost that you desire. I have been told NOT to try this if it is not a tube buffered preamp.
VanWyck is offline
post #9 of 10 (permalink) Old 02-13-2003, 12:50 PM
EG- set the gain really low on the DS-1 and the level for a slight but noticeable volume boost when you hit it on the clean channel. You don't need to add much gain, just "massage" the lead channel a little bit.
-Drew
Drew is offline
post #10 of 10 (permalink) Old 02-13-2003, 09:25 PM Thread Starter
eg
On the lead or clean channel??
eg is offline
combo amp , dimebag darrell , distortion pedal
Roland Jazz chorus vs Marshall clean channel MatiasTolkki Gear, Equipment, Recording & Off Topic 9 12-01-2013 08:28 AM
Using the tube overdrive or clean channel with a pedal? guitarnoize Gear, Equipment, Recording & Off Topic 2 12-21-2008 09:52 PM
HELP, i need help on fixing my amp!! - My clean channel is w wolfgang Gear, Equipment, Recording & Off Topic 0 07-19-2001 12:27 PM
Probs with clean channel on Tremoverb - only comes out low v trapzilla Gear, Equipment, Recording & Off Topic 2 01-22-2001 04:38 AM
