Combos & Hotplate - Jemsite
post #1 of 9 (permalink) Old 09-02-2005, 06:29 AM Thread Starter
Smile Combos & Hotplate
I've got a silly question which I hope will not make me look dumb
Can the THD hotplate be used with a Combo Tube amp?? I know power attenuators are normally used with heads & cabs but what about combos?
Also, what is a suitable wattage tube amp which has sound levels (i.e. tubes fully driven) suitable for bedroom playing? Is there some kind of comparison chart for different sizes of amps?
blackpuppets is offline
post #2 of 9 (permalink) Old 09-02-2005, 06:33 AM
Re: Combos & Hotplate
Bedroom? Maybe 5-15 Watts.
King Knall is offline
post #3 of 9 (permalink) Old 09-02-2005, 06:37 AM Thread Starter
I've heard that solid-state amps of the same wattage are not as loud as tube amps. Is it true?
post #4 of 9 (permalink) Old 09-02-2005, 08:24 AM
Not silly at all, really... it's perfectly fine to use an attenuator with a combo. In most combos, it's possible to unplug the internal speaker. So run the speaker out into the attenuator, then plug the speaker into the attenuator. You may need a speaker extension cable to pull this off.
In combos where the speaker is hardwired in, technically it's still possible, but you'd probably have to cut the wire and put in a couple 1/4" jacks to have an insert point for the attenuator.
--B
bduersch is offline
post #5 of 9 (permalink) Old 09-02-2005, 01:52 PM
And there is no point in turning a solid state amp up as well as they dont sound better when you dime them like tubes....
You can use a hotplate with a combo amp as long as the speaker is plugged in with a 1/4 inch input jack so that you can plug that into the hotplate and plug the hotplate into the amp as well..
Be sure to match the impedance - they make hotplates in 4, 8 16 and some oddball impedances like 2.7 so you should be alright.
red5 is offline
post #6 of 9 (permalink) Old 09-02-2005, 03:00 PM
Tube amp for bedroom playing? Something like...hmm...2 watts?
I am glad you asked the hotplate question actually, as I was wondering the same thing.
pawel is offline
post #7 of 9 (permalink) Old 09-02-2005, 10:32 PM
Even 1 watt cranked is loud. I would suggest a combo with a post phase inverter master volume and a hotplate like a marshall dsl201 or 401.
Rudy is offline
post #8 of 9 (permalink) Old 09-03-2005, 04:17 AM
true
believe it or not, to be comfortable you should go down to 0.1 watt, like the Z-vex
here you will find lots of infos on this problem, it's a personal webpage freely written by an amplifier engineer ---> www. amptone.com
machinediva is offline
post #9 of 9 (permalink) Old 09-03-2005, 04:47 AM Thread Starter
What does 'headroom' mean? I keep reading threads about how wattage is related to headroom, just not sure what it means....
combo amp , extension cab , marshall dsl , solid state amp , thd hotplate , tube amp , tube amps
effects combos? AlaskaBat Gear, Equipment, Recording & Off Topic 47 05-31-2012 04:10 PM
p'up combos liam894 Pickups & wiring 5 11-02-2008 08:58 AM
Tube combos Eco Gear, Equipment, Recording & Off Topic 10 09-10-2007 06:49 PM
Combos vs. Stacks kirk Gear, Equipment, Recording & Off Topic 13 09-10-2002 08:36 AM
Anyone using Marshall DSL/TSL combos? - Particularly the JCM bduersch Gear, Equipment, Recording & Off Topic 1 03-20-2002 01:38 AM
