Compression - what the??? - Jemsite
post #1 of 8 (permalink) Old 01-07-2003, 05:12 AM Thread Starter
Hey all
I was wondering if anyone could tell me what there view is on using compression. I have the option of using it but don't seem to like it very much, it just seems to dampen the sound, make the gain drop to much.
What would you use compression for? and what is it?
thanks
Dave Goodland is offline
post #2 of 8 (permalink) Old 01-07-2003, 07:20 AM
I use it whenever I have to switch to finger-picking because I'm not a great hybrid picker and if I don't use a little compression the bass note I hit with the pick will stand out from the notes I pluck with my fingers - so in our current list I use it on a lot of Stray Cats stuff, Desperado (Alice Cooper), Sultans of Swing and some Eddie Cochran stuff. I also like using it to squeeze out a familiar country flavor on the ol' Tele. I never use compression with any gain, since there's plenty of compression in an OD pedal or overdriven tubes anyway... my 2¢
Jimi D is offline
post #3 of 8 (permalink) Old 01-07-2003, 10:38 AM
it depends on what style you play:
if you play Pantera's stuff or Metallica, then get compressed. if you play simple rock, blues, jazz or whatever, then dont compress your sound.
you should use it when you need an even volume and no dynamics. it squeezes your signal dynamics, i.e: low-volume will get pumped, and high-volume will be cut, to give your sound even 'boundaries' to be driven in.
nuno is offline
post #4 of 8 (permalink) Old 01-07-2003, 01:02 PM
Just compress if you like the sound. There's no rule.
Your dampened effect is caused by over-compression.Slack on the ratio and threshold and then balance your input gain versus your output gain. You may be very welll surprised at what comes out!
Cheers
Pat
30yroldpig is offline
post #5 of 8 (permalink) Old 01-07-2003, 09:02 PM
If anything, I use my compressor to add sustain into my distortion..I could care less about how "even" the sound is..I rarely use it anymore, it's byproduct of added noise isn't worth the benifit..Just my opnion though...
Sephiroth000 is offline
post #6 of 8 (permalink) Old 01-07-2003, 11:03 PM
I really dont fully understand compression either. I use it though lol. It just seems to make my sound a bit more focused and adds a little tightness and chunk. I like the effect of it, so ill probably keep usin it. Just tweak it a bit to see if you can get good results, if not dont use it :-)
Guitarlos2 is offline
post #7 of 8 (permalink) Old 01-08-2003, 12:13 AM
Compression is simple, imagine your guitar signal as it looks on an osciliscope (as a simple sine wave). Without compression your signal has no boundries, other than the limitations on how much magnetic field you can disturb (i.e by normal playing) and what the maximum voltage capacity of your pickup's are (how efficient and/or large the magnets are). Compression "squeezes" the upper and lower boundries to a desired level (reducing extreme voltages caused by the dynamics of your playing), these are what cause erratic and uncontrolled loud sounds. Since compression limits these voltages it makes your sound more controlled and "stable".
Soloist is offline
post #8 of 8 (permalink) Old 01-08-2003, 03:21 AM
A most excellent explanation, Soloist. TKS.
bpd111 is offline
What is Compression? Thrash Pickups & wiring 6 03-24-2008 07:26 PM
compression pedal...? chopvai Gear, Equipment, Recording & Off Topic 5 03-14-2008 01:15 PM
Too much compression kpinks Gear, Equipment, Recording & Off Topic 1 02-26-2008 08:14 AM
Compression On Evos Thrash Ibanez JEM, UV, JS & Other Signature Models 13 03-10-2006 04:33 AM
What is Compression? nott^^ Gear, Equipment, Recording & Off Topic 6 09-10-2004 06:43 AM
