Cool Edit Pro questions - Jemsite
post #1 of 5 (permalink) Old 04-19-2003, 11:12 AM Thread Starter
Ok, my first question is this...right now I'm using Cool Edit Pro without a mixer or anything, and I want to record using the line-in on my sound card. Where do I set it so it records from line in?
Question 2...When I try importing a .wav file, it compresses it horribly...any way to not compress it?
Jeff is offline
post #2 of 5 (permalink) Old 04-19-2003, 01:21 PM
well, you want to open your volume control beside your clock, then go to options>properties>recording
then select Line-In.
I'm not sure about your 2nd question though
Vai the god of Sound is offline
post #3 of 5 (permalink) Old 04-19-2003, 01:44 PM Thread Starter
I did as you said, and it didn't work. Am I supposed to uncheck everything BUT line-in or what?
Jeff is offline
post #4 of 5 (permalink) Old 04-19-2003, 04:35 PM
What do you mean, "import"? You should be able to just OPEN a wav file, unless the headers are screwed up somehow.
JESTER700 is offline
post #5 of 5 (permalink) Old 04-19-2003, 06:55 PM Thread Starter
Ok, I think I got it all figured out now thanks to kennydoe. Thanks for your help everyone!
Jeff is offline
PODXT PRO + Cool Edit help! AMD1014 Gear, Equipment, Recording & Off Topic 0 05-26-2007 12:56 PM
Cool Edit Pro 2.1 Problem- Need Answer Fast! Ozzdoc Gear, Equipment, Recording & Off Topic 1 05-10-2006 06:36 AM
cool edit guitario Gear, Equipment, Recording & Off Topic 7 03-04-2004 08:26 PM
cool edit pro 2.0 guitario Gear, Equipment, Recording & Off Topic 1 03-02-2004 05:25 PM
Cool Edit Pro or Cakewalk Homestudio 2002 ????? wireman24 Gear, Equipment, Recording & Off Topic 2 03-31-2003 08:33 AM
