Cubase problem - Jemsite
post #1 of 3 (permalink) Old 02-01-2003, 08:13 AM Thread Starter
Cubase problem
There's this thing that really bugs me: whenever I record something, it doesn't only save the .wav files that make the final cut, but also all the ones I don't keep. Sometimes it takes a ridiculous amount of takes and different parts to record a song, and I end up having hundreds of .wav files on my hard drive for one song. Anyone knows how to make it keep the right ones only?
thanks!
John is offline
post #2 of 3 (permalink) Old 02-02-2003, 08:01 AM
If you're deleting the files with the rubber they stay on the drive, if you select the file you wish to delete and press Ctrl & backspace (I'm going from memory here for PC) it will ask you if you want to delete the file completely.
Also you should go into the audio pool and purge the files, this way it will tell you which files are currenly being used.
I'd make a backup first before you do any of these things until you get used to it.
An alternative is to ask Mr Vai to come down and lay down your guitar parts for you. That way you'll never need to use the rubber
Ant711UK is offline
post #3 of 3 (permalink) Old 03-13-2003, 12:45 PM Thread Starter
Yeah man that was it! Thanks a whole lot!
John is offline
Beginner Cubase VST 4.0 problem not2secure4u Gear, Equipment, Recording & Off Topic 1 11-29-2005 12:35 PM
Could somebody please help with cubase? sam_at2001 Gear, Equipment, Recording & Off Topic 0 10-17-2005 07:47 AM
cubase sx 3.0 dirtyissues Classified Ads: Guitars and Gear 6 09-07-2005 05:18 PM
BR8 to Cubase - Having trouble recording BR8 to Cubase MikeyJ Gear, Equipment, Recording & Off Topic 4 02-28-2002 07:01 PM
