Delay settings for your lead sound - Jemsite
post #1 of 5 (permalink) Old 05-25-2003, 11:45 AM Thread Starter
what sort of settings do you guys use for your lead sound?
FinnJ is offline
post #2 of 5 (permalink) Old 05-25-2003, 01:26 PM
My standard default setting is 400ms at about 10%mix.
I have my G-Major set up to go there when I switch presets. I can tap tempo from my Lexicon MPX r1 controller and I have the expression pedal set to control the Mix.
So I can go from 10% (all the way back) to 70% all the way forward. This gives me the ability to stay within the "tapped" delay and add delay as needed.
oooo is offline
post #3 of 5 (permalink) Old 05-25-2003, 01:28 PM
I use about 400ms and have about 3 repeats and set the level for about 50%.
motogod927 is offline
post #4 of 5 (permalink) Old 05-25-2003, 04:34 PM
500ms and 20% in mix.
jemke is offline
post #5 of 5 (permalink) Old 05-26-2003, 06:03 AM
492ms
25% feedback
15% mic
DracWell is offline
expression pedal , lexicon mpx
How do you get this lead sound? moro Gear, Equipment, Recording & Off Topic 13 03-18-2005 01:33 PM
delay settings? woodros Gear, Equipment, Recording & Off Topic 2 02-13-2004 06:42 PM
What are your delay and/or reverb settings? pri0531 Gear, Equipment, Recording & Off Topic 17 11-16-2001 01:34 PM
Lead Boost with an EQ pedal - What are your settings? revsharp777 Gear, Equipment, Recording & Off Topic 2 07-30-2001 01:14 PM
Delay settings for a Midiverb 4 pri0531 Gear, Equipment, Recording & Off Topic 2 02-16-2001 02:22 PM
