Difference between Class A and AB Amp - Jemsite
post #1 of 4 (permalink) Old 08-10-2009, 02:43 AM Thread Starter
Reviews: 14
Can anyone tell me that's the difference between Class A and Class AB amp? Do they have more class? Like C, D , E?
Thanks,
here.choo is offline
post #2 of 4 (permalink) Old 08-10-2009, 03:06 AM
Re: Difference between Class A and AB Amp
There are more than just A and AB. It has to do with the way the power tubes are used.
Heres a great (and very long) article by Randall Smith describing it all.
http://www.mesaboogie.com/US/Smith/C...WebVersion.htm
But honestly, there isnt much difference in terms of tone. There may be a slight difference you can hear, but all the 'Class A is the best' stuff is really just advertising hype.
littlephil is offline
post #3 of 4 (permalink) Old 08-10-2009, 11:15 AM
Briefly,
Class A has all the waveform going to each of the tubes, in fact, often there is only one tube.
Class B has opposite halves of the waveform going to each of the tubes, positive to one, negative to the other.
Class AB is somewhere in between with all the positive and a bit of the negative going to one tube and all the negative and a bit of the positive going to the other.
Many people think the VOX AC30 is class A, but it's really AB, although biased towards A, but if you turn it down it will operate as Class A.
http://www.duncanamps.com/technical/...of%20Operation
for further info
Jim
Vim Fuego is offline
post #4 of 4 (permalink) Old 08-10-2009, 11:23 AM
And part of the 'older/retro is always best movement'.
That Boogie article is ace btw.
Sickbean is offline
amp
NGD. I got Cat Class & I Got Cat Styyyyle elcid All Other Guitars (including Prestige) 21 05-11-2008 09:23 PM
My project for Art class Spider-Skot Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 11 04-25-2006 09:29 PM
JSX Class Praetorian Gear, Equipment, Recording & Off Topic 24 05-12-2005 05:48 PM
Class A, Class A/B and Solid state sanchez Gear, Equipment, Recording & Off Topic 6 12-09-2003 05:40 PM
