Difference between normal P.U. and F spaced P.U. - Jemsite
post #1 of 6 (permalink) Old 07-27-2006, 06:37 PM Thread Starter
Question Difference between normal P.U. and F spaced P.U.
So, what's the difference between normal P.U. and F spaced P.U.?
AleTheNervo is offline
post #2 of 6 (permalink) Old 07-27-2006, 06:41 PM
Re: Difference between normal P.U. and F spaced P.U.
Straight off of Dimarzio.com
What is F-spacing?
All of our full-size humbuckers except the X2N® are available in two polepiece spacings. F-spacing refers to the wider of the two spacings. For proper string alignment and balanced output, F-spaced humbuckers should be used in the bridge position on all guitars with string spacing at the bridge of 2.1" (53 mm) or greater. On these guitars, if the nut width is 1-11/16” (43 mm) or greater, F-spaced pickups can be used in the neck position as well.
Why are there two different spacings?
A long time ago (in the 20th century, actually) the electric guitar world was divided between Gibson and Fender designs. One of the differences between the two was string spacing. In general, Gibson chose a narrower string spacing at the bridge than Fender, and therefore the polepieces on Gibson humbuckers were closer together than the magnets on Fender pickups. When
guitar shops started installing humbuckers in the bridge position of Strats, it was obvious that the strings didn’t line up with the polepieces, and if the E strings were too far outside, the sound could suffer. Our first humbuckers followed the original Gibson spacing, and we call them standard-spaced. When we released our first humbuckers with wider spacing, Floyd Rose bridges were very popular. Floyd string-spacing is the same as Fender spacing, so we naturally called the new pickups F-spaced.
How do I know which spacing to use?
F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm). Although some players believe that F-spaced pickups are only for the bridge position of tremolo bridge guitars, many guitars with fixed bridges (including late 1990s Gibson Les Pauls and Epiphone LPs) should have F-spaced pickups in the bridge position. Most tremolo equipped guitars that have a nut width of 1-11/16” (43mm) or more should also use an F-spaced pickup in the neck position. If you’re replacing a bridge-position pickup and you're not sure what your string-spacing is, it's usually better to get an F-spaced model. It is not necessary for the strings to pass exactly over the center of the polepieces for best performance, but it is wise to avoid a situation where the E strings are sitting completely outside of the outer polepieces.
Do some of your humbuckers come only in one spacing?
The X2N® has solid bar polepieces that work in both normal and F-spaced applications. All 7-string humbuckers are available F-spaced only. All Parker Fly replacement pickups are F-spaced only.
Is there F-spacing for single-coils?
All of our single-coil-sized pickups are designed for F-spaced applications.
Kontalonis is offline
post #3 of 6 (permalink) Old 07-27-2006, 06:41 PM
Dee
EDIT: Replied at the same time as Kontalonis.
Dee is offline
post #4 of 6 (permalink) Old 07-27-2006, 06:43 PM
Hehe sorry Dee, didn't mean to step on any toes.......i forgot how much all jemsiters like to help.
post #5 of 6 (permalink) Old 07-27-2006, 06:44 PM
Dee
No apologies needed, thanks man.
Dee is offline
post #6 of 6 (permalink) Old 07-27-2006, 06:45 PM Thread Starter
Thanks guys!
bridge position , electric guitar , equipped guitar , fixed bridge , floyd rose , floyd rose bridge , gibson les paul , gibson les pauls , guitar shop , les paul , les pauls , neck position , parker fly , spaced pickup , tremolo bridge
The difference a BBE sonic maximiser can make wilch Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 46 11-06-2008 02:22 PM
does body type really make a difference? teddyastuffed All Other Guitars (including Prestige) 9 05-15-2005 04:06 AM
Difference: LA Custom Shop - normal Ibanez Timon All Other Guitars (including Prestige) 8 08-30-2002 12:05 PM
Difference between JPM100 P1, P2, P3 and P4 - Any difference MrNiceguy87 All Other Guitars (including Prestige) 5 02-05-2002 06:44 AM
