Different radius necks and the Edge-Pro - Jemsite
post #1 of 12 (permalink) Old 08-14-2006, 05:48 PM Thread Starter
I plan on putting a Wizard II neck on my lefty prestige that has the Edge-Pro trem.
My question is will the 400mm radius on the Wizard II neck have any negative effect on action considering the Edge-Pro is designed to be used with a 430mm neck?
chilln2music is offline
post #2 of 12 (permalink) Old 08-14-2006, 06:36 PM
Re: Different radius necks and the Edge-Pro
That's a pretty small difference really. But you can always adjust the bridge radius with saddle shims (under the saddles) to match the neck if you like.
ryanb is offline
post #3 of 12 (permalink) Old 08-14-2006, 06:40 PM
Yes, saddle shims. Where's a good place to buy them? Or do people just fabricate their own?
giannifive is offline
post #4 of 12 (permalink) Old 12-03-2007, 01:26 PM
ggmalcolm
Guest
Posts: n/a
I JUST SHIMMED MY RG1820X SADDLES ...
GO TO THE DOLLAR STORE AND BUY THE CHEAP TINFOIL, IT IS VERY THIN AND CAN BE FOLDED TO ADD MORE HEIGHT. IT WORKED GREAT AND NOW THE SADDLES ARE PERFECT WHAT A DIFFERENCE IN PLAYABILITY.
post #5 of 12 (permalink) Old 12-03-2007, 02:04 PM
CosmicDebris's Avatar
Hey buddy how about fixing that Caps Lock key, seems to be stuck.
CosmicDebris is offline
post #6 of 12 (permalink) Old 12-03-2007, 03:34 PM
ggmalcolm
Guest
Posts: n/a
I was just trying to help and din't know there would be a typing test involved .. no worries I 'll be on my way and not share any more info.
Be careful it's a long way down off that high horse.
post #7 of 12 (permalink) Old 12-03-2007, 03:43 PM
no need to be snooty, get over it. nobody anywhere takes kindly to unnecessary capslocking.
Ki swordsman is offline
post #8 of 12 (permalink) Old 12-03-2007, 04:05 PM
With such great information lost, what will we ever do?
I used to cut up Pepsi cans to make shims, now I have a fabricator make them in 4 thicknesses, 300 at a time. Very useful for correctly radiusing edge pro bridges.
Rich is offline
post #9 of 12 (permalink) Old 12-03-2007, 04:05 PM
Bye bye, take care and come back when you can't stay. I just love "I am gonna take my ball and go home." folks. Dude if you get riled up over something like that then you have a rude awaking in store when you enter the real world.
post #10 of 12 (permalink) Old 12-04-2007, 12:13 PM
ScottB's Avatar
Give 'em the benefit of the doubt. I hear that PMS, menstrual cramps and elevated estrogen levels can wreak havoc on one's emotions at certain times of the month.
ScottB is offline
post #11 of 12 (permalink) Old 12-04-2007, 12:26 PM
So I should buy stock in midol? If he had not became snotty I would have said I thought the tin foil was a good idea but I won't now
post #12 of 12 (permalink) Old 12-04-2007, 03:31 PM
ScottB's Avatar
Just joking - note the
That dude needs to wear a tinfoil hat and skip the saddle shim advice.
ScottB is offline
edge pro bridge , edge pro bridges
