Digitech Drop Pedal's ground loop hum - Jemsite
post #1 of 3 (permalink) Old 07-26-2016, 11:47 AM Thread Starter
Hello, folks!
Any of you who owns a Digitech Drop pedal?
Is the ground loop hum normal when the both the Drop and other distortion pedals are on? I'm thinking of isolating the Drop by powering it with a spare PSU I have to eliminate this.
Thank you!
ermonski is offline
post #2 of 3 (permalink) Old 07-26-2016, 02:12 PM
Re: Digitech Drop Pedal's ground loop hum
No hum here. Good cables & good power unit could help.
Hating-pyramids is offline
post #3 of 3 (permalink) Old 07-26-2016, 08:37 PM
No issues with mine at all. I would check your power supply. It needs at least 300mv. Make sure you are using either the adapter that came with it or some kind of power unit that has isolated outputs like the Voodoo lab stuff. Other than that, check cabling and your other pedals for issues. Use one at a time to diagnose where the issue is.
PBGas is offline
digitech , drop , drop tune , ermonski , pedal
Digitech DROP pedal excellent lynchfan6 Classified Ads: Guitars and Gear 1 06-08-2016 06:18 PM
All of the sudden Ground hum AmazinAzian12 Pickups & wiring 9 04-29-2015 08:52 AM
ground loop prevention qwesion 2DECADESSOFAR Pickups & wiring 0 11-18-2012 09:20 AM
Ground Loop? LethalAe86TypeR Gear, Equipment, Recording & Off Topic 6 08-29-2007 08:42 PM
Legacy effect loop - possible ground loop hum? bill h Gear, Equipment, Recording & Off Topic 4 08-12-2001 03:05 PM
