Digitech RP500 Headphone problem - Jemsite
post #1 of 7 (permalink) Old 04-30-2011, 06:23 PM Thread Starter
Reviews: 4
Hello. I have had my digitech RP500 for a little over a year. I am having a problem with the headphone jack: The center channel of the stereo is not there - Only the reverb and chorus is there, not anything center-panned (but it is also strangely all mono now as well). I have tried Using different headphones, same problem, Using the mono and stereo outputs to an amplifier or heaphones work fine. I am using the first firmware with the looper, not sure which number. This problem seemed to happen somewhere in the middle of a recording session, but not sure of the exact moment.
I also had a similar problem where when I plugged a MP3 player or other device into the AUX input, the center channel would not be there. Oddly enough, this problem lasted for at least 6 months and went away for only about a week until this new problem above started.
I was wondering which action would be best, If I should start with a master reset, open it up to check for loose connections etc.
fwd0120 is offline
post #2 of 7 (permalink) Old 04-30-2011, 07:07 PM
Re: Digitech RP500 Headphone problem
sounds like a jack problem, if it's still on warrenty, make it check, or ask a qualified technician to verify your system.
modulo is offline
post #3 of 7 (permalink) Old 04-30-2011, 09:16 PM Thread Starter
Reviews: 4
thanks! any other takers?
fwd0120 is offline
post #4 of 7 (permalink) Old 05-01-2011, 11:09 AM Thread Starter
Reviews: 4
bump.
fwd0120 is offline
post #5 of 7 (permalink) Old 05-01-2011, 04:38 PM Thread Starter
Reviews: 4
Well, I tried doing a master reset. didn't help at all. wiggling the headphone plug in the socket didn't change anything. what now?
fwd0120 is offline
post #6 of 7 (permalink) Old 05-01-2011, 09:02 PM Thread Starter
Reviews: 4
Okay, A bit of an update:
Installed new firmware - nothing.
Beat the thing within an inch of it's life (bruised my hand) - nada
Tried every combination of guitar, cable, heaphones, and even tried reversing the polarity on the PSU - ...... zip.
So, is it just defective?!? Not entirely sure exactly the moment it happened - BUT the WAS a small power surge before the time this started happening, but I wasn't paying enough attention to know if that is the cause, I didn't really catch it at the time, but that just hit me as a distinct possibility.
So where do I go from here? I am 3 weeks out of the warranty, but I did contact them for a very very similar issue days before it would have expired, but recieved no further contact (the said they would call back, didn't)
EDIT: ALSO!!! When it is in the tuner mode, sound comes out normally! could this be a wacko software issue?!?
fwd0120 is offline
post #7 of 7 (permalink) Old 05-01-2011, 10:00 PM Thread Starter
Reviews: 4
fwd0120 is offline
digitech rp500, boss gt 10 or pod X3 live/HD 500 for petrucci sound? dreamtallica Gear, Equipment, Recording & Off Topic 30 12-12-2010 09:29 AM
Zoom G7.1 ut or Digitech RP500 cmd130 Gear, Equipment, Recording & Off Topic 7 06-02-2010 09:52 AM
pod xt live vs digitech rp500 fatal1ty39 Gear, Equipment, Recording & Off Topic 25 01-03-2010 11:14 AM
Digitech RP500 in the FX Return/Power Amp In theapprentice Gear, Equipment, Recording & Off Topic 0 09-30-2009 08:20 AM
Any thoughts about the Digitech RP500 Indylawguitar Gear, Equipment, Recording & Off Topic 2 04-22-2009 08:37 AM
