Dimarzio F? or regular. - Jemsite
post #1 of 7 (permalink) Old 10-30-2010, 12:54 PM Thread Starter
Reviews: 7
Question Dimarzio F? or regular.
Hello guys, need help.
someone gave me a brand new Dimarzio breeds humb, bridge and neck.
but its not an F spaced, would i'll be able to ,work it out on my RG-550,
with a Floyd Rose Bridge? or i can only used an F SPACED pickups.
Thanks.
SHAIBANEZ is offline
post #2 of 7 (permalink) Old 10-30-2010, 01:00 PM
Re: Dimarzio F? or regular.
http://www.dimarzio.com/site/#/faq/
How do I know which spacing to use?
F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm). Although some players believe that F-spaced pickups are only for the bridge position of tremolo bridge guitars, many guitars with fixed bridges (including late 1990s Gibson Les Pauls and Epiphone LPs) should have F-spaced pickups in the bridge position. Most tremolo equipped guitars that have a nut width of 1-11/16” (43mm) or more should also use an F-spaced pickup in the neck position. If you’re replacing a bridge-position pickup and you're not sure what your string-spacing is, it's usually better to get an F-spaced model. It is not necessary for the strings to pass exactly over the center of the polepieces for best performance, but it is wise to avoid a situation where the E strings are sitting completely outside of the outer polepieces.
http://www.jemsite.com/forums/f18/rg...ced-80158.html
http://www.jemsite.com/forums/f35/rg...ot-106574.html
http://www.jemsite.com/forums/f35/wh...0-a-45470.html
http://www.jemsite.com/forums/f18/pi...ing-41272.html
http://www.jemsite.com/forums/f15/je...ing-97077.html
http://www.jemsite.com/forums/f18/f-...-rg-39973.html
Diamond Dave is offline
post #3 of 7 (permalink) Old 10-30-2010, 01:01 PM
I wouldn't worry about it, it's mostly visual difference. You can bring outer poles a bit higher to compensate...
bancika is offline
post #4 of 7 (permalink) Old 10-30-2010, 01:03 PM Thread Starter
Reviews: 7
F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm). Although some players believe that F-spaced pickups are only for the bridge position of tremolo bridge guitars, many guitars with fixed bridges (including late 1990s Gibson Les Pauls and Epiphone LPs) should have F-spaced pickups in the bridge position. Most tremolo equipped guitars that have a nut width of 1-11/16Ē (43mm) or more should also use an F-spaced pickup in the neck position. If youíre replacing a bridge-position pickup and you're not sure what your string-spacing is, it's usually better to get an F-spaced model. It is not necessary for the strings to pass exactly over the center of the polepieces for best performance, but it is wise to avoid a situation where the E strings are sitting completely outside of the outer polepieces.
Thanks for the prompt respons, i know what i need to do.
post #5 of 7 (permalink) Old 10-30-2010, 02:20 PM
Reviews: 98
You do not need to put F spaced pups in a Floyd equipped guitar! Regular spacing works just fine. You know, F spaced pups came out many years after Floyds.
AlaskaBat is offline
post #6 of 7 (permalink) Old 10-30-2010, 03:27 PM
i agree 100%....i had an f-spaced bridge pickup in a les paul for a long time and it worked just fine....there was no tonal difference i could tell when i finally swapped it for the proper spaced one
Kev-o-matic is offline
post #7 of 7 (permalink) Old 10-30-2010, 04:35 PM Thread Starter
Reviews: 7
thanks guys.
pickup
WTB Dimarzio fred f spaced and dimarzio paf pro regular spaced. flyinryan11 Classified Ads: Guitars and Gear 2 03-17-2009 05:55 PM
f-spaced or regular? kshands Tech: Setup, Repairs and Mods 13 02-08-2009 03:55 PM
dimarzio pups, regular or with f-spaced? son_of_zion Pickups & wiring 9 04-04-2007 06:40 PM
anyone have a regular norton ? j.arledge Pickups & wiring 7 12-31-2005 07:59 PM
Regular Wiring RSVampire Pickups & wiring 6 12-31-2002 07:13 PM
