Dodgy power supply? please help! - Jemsite
post #1 of 5 (permalink) Old 10-09-2012, 08:36 AM Thread Starter
Hi guys,
I have a Bugera 333 Infinium head, and run my pedals as follows
Boss TU-2 -Morley Bad horsie - Biyang x Drive - Front of amp
Biyang Aqua chours - Digitech Delay - Behringer noise suppressor - into fx loop
I power my pedals using the Harley Benton power plant, and on the clean channel of my amp it works normally, but as soon as i go on the crunch/lead channels i get a loud horrible sounding Buzz/Hum that even my noise suppressor won't cure.
After this i tested every pedal with the power plant separately and still i got the same noise.
after this i tried all my pedals through the amp with batteries and everything sounded normal, so my first thought was the power plant was faulty.
the other day i decided to buy a plug/daisy chain to replace the power plant, and when it came i wired up all my pedals again, and too my dissapointment the horrible noise was still there! so then i thought it has to be the mains i am running off so i tried different plug sockets all over the house and nothing changed, i even took my gear to my next door neighbors house and still the buzz was there.
I have tried to find out what is causing my problem, but i am just stuck on what to do, i have read up i need an 'isolated' power supply, but i don't want to keep throwing away my money.
I anyone has had similar problems or could help me with my issue i would really appreciate it
Thanks Guys
Dannymanc81 is offline
post #2 of 5 (permalink) Old 10-09-2012, 03:06 PM
jb4674's Avatar
Reviews: 18
Re: Dodgy power supply? please help!
You need one of these:
Or one of these:
Jimmy
jb4674 is offline
post #3 of 5 (permalink) Old 10-09-2012, 05:47 PM
Reviews: 120
Sanyo Pedal Juice. Acts like batteries, but external supply. I use mine with about 6-7 pedals and the charge lasts for one month before I need to charge it again.
LonePhantom is offline
post #4 of 5 (permalink) Old 10-14-2012, 06:44 PM Thread Starter
Thanks guys
I just want to ask, as i get noise on the dirty channel on my amp, would i be right in saying i need an 'isolated' power supply?
post #5 of 5 (permalink) Old 10-14-2012, 09:54 PM
Reviews: 4
Make sure your house wiring is properly grounded, too. Almost NONE of the sockets in my 50-year-old house are properly grounded, which makes things MUCH noisier and even possibly dangerous (especially with my 500watt bass amp rig).
But there's a great video demonstration by Taylor guitars about how much noisier your rig is without proper grounding. It never occurred to me that my "noisy" single coil guitar might be quieter if I just used the right wiring setup. But there you are.
Ekim is offline
battaries , broken , power supply
Whammy IV with box and power supply Sevenstringer Classified Ads: Guitars and Gear 1 07-21-2011 01:41 AM
FS: EHX Micro POG + power supply Toadfish Classified Ads: Guitars and Gear 1 12-31-2010 08:05 AM
WTB: Boss PSA-120(Boss normal power supply), or any supply that will work GuitarEvan07 Classified Ads: Guitars and Gear 1 06-03-2009 11:33 PM
BOSS PS-2/CE-3/TU-2/OC-2/T.C. Electronic power supply/MORLEY Power Wah BOOST Sevenstringer Classified Ads: Guitars and Gear 12 05-09-2008 04:05 PM
power supply... chopvai Gear, Equipment, Recording & Off Topic 3 02-24-2008 09:02 PM
