Drum triggers? - Jemsite
post #1 of 4 (permalink) Old 09-12-2007, 01:36 PM Thread Starter
Drum triggers?
Do you guys who use these drum pads play the drums or do you just play crappy on the trigger and then let the sequencer fix it up? I'm pulling my hair out trying to find the easiest method to record drum tracks. Rusty Cooley used an old DR-5 on some of his earlier tracks. He programmed it then ran each piece through it's own track. Cool idea, but still seems like a lot of work.
This has slowed down my recording time tremendously.
BigShred is offline
post #2 of 4 (permalink) Old 09-12-2007, 02:03 PM
Re: Drum triggers?
You might think about using looping software like Acid or Fruity Loops or something. You get studio recorded drums, and you just drag and drop different drum parts into your song. All styles are available, and it's really pretty easy to use.
TAorama is offline
post #3 of 4 (permalink) Old 09-16-2007, 02:00 AM
ME.
Re: Drum triggers?
Try Toontracks EZDrummer. I use it with Cubase, works great.
Colin
ME. is offline
post #4 of 4 (permalink) Old 09-20-2007, 05:46 PM
Re: Drum triggers?
Colin
Yeah its the best drum software you can get.
about 7500 different drum loops, including fills, and time sigs like 6/8, 3/4 e.t.c.
It causes a lot of problems with cubase though, try using Steinberg Nuendo with it instead.
twooos is offline
drum tracks , fruity loops , rusty cooley
what are drum triggers? C.Thep Gear, Equipment, Recording & Off Topic 3 07-02-2007 11:15 PM
Drum Kit From Hell Superior?? B18CB0Y Gear, Equipment, Recording & Off Topic 8 09-17-2004 12:35 PM
Can anybody help with drum machines/drum programming? sam_at2001 Gear, Equipment, Recording & Off Topic 4 06-09-2004 10:09 PM
What can i make drum sequences in? i cant read drum tab so.. Swirly Gear, Equipment, Recording & Off Topic 8 09-10-2003 04:00 PM
Looking for good Drum Machine cowcowcow Gear, Equipment, Recording & Off Topic 6 01-26-2001 01:23 PM
