DS-1 on bypass - Jemsite
post #1 of 4 (permalink) Old 05-30-2003, 02:58 PM Thread Starter
DS-1 on bypass
I just noticed that when my DS-1 is on bypass, my sounds (especially clean) sound worse than when I plug directly into my amp. Do other pedals do this? TS7?
Lauri M is offline
post #2 of 4 (permalink) Old 05-30-2003, 03:42 PM
Yes, to some degree all pedals will affect your sound. The ones that will affect it to a lesser degree will be the true-bypass ones, and most of those are made by the botique guys. Some of them also offer mods to existing pedals for true bypass. Boss, Roland, Ibanez and such are not true bypass in their stock form.
glynn is offline
post #3 of 4 (permalink) Old 05-30-2003, 05:11 PM
If you break things down to the ultimate level, anything will effect your sound. The Air & space around your guitar.
But for practicality sake, youd be hard pressed to find a human being who can tell the difference between a strait signal and a signal running through a true bypass switch. Even Eric Johnson doesnt claim to be able to do that. Only A-B boxes with LED's. Real TB switches take the signal completely out of the circuitry when bypassed and only run the signal through the metal components of the switch itself. If you can tell that difference and dont like it, may I suggest wiring your pickup strait to the jack so you dont have to mess with those nasty sounding pots and switches in your guitar (sarcasm).
Like Glynn said you wont find a TB switch on just about 99% of production pedals. Boutique pedals are expensive but thier basically all that I, and many other people, will use. If it means that much to you theres some great products out there that have TB loops that you run to and from your non-TB pedal. In a sense they then become TB. Check out the Pedal-Racks Bypass Strip.
http://www.musictoyz.com/pedalracks.htm
Its a bunch of TB switches lined up one after the other that can switch in and out any thing you plug into it. You cant get much better then that without being completely impracticle.
Dan D Mahnn is offline
post #4 of 4 (permalink) Old 06-13-2003, 07:52 AM
One thing that will improve the fidelity of any of your FET-based switched pedals is the power supply voltage. As it goes down, so does the fidelity and output volume. I try to make sure my pedals are compatible with 9.6 to 9.8 volts and with that the circuitry is sounding pretty darn okay.
Those circuits are desgined to be buffers with little frequency shaping. It is possible to improve the response a tiny bit by replacing the caps around those sections. Sometimes it is also possible to increase the input resistance a bit for a "more 1-to-1" sound.
Important things to look at for the DIY guy are the first and last capacitors. Just moving to polyprop... will make a small but noticeable difference. Try www.digi-key.com for their Panasonic variety, they are very expensive, 3 times more than the Metal film!!! But again, worth it in my book.
I hope that helps.,
Robert
going to see CSN tonigh...I wonder if they'll have a DS-1 he, he, he
rk
Keeley is offline
eric johnson
True Bypass, Do you really need it? Lussy Picker Polls 9 03-10-2010 03:35 PM
difference between true bypass and true hardwire bypass? Valhalla Gear, Equipment, Recording & Off Topic 0 10-15-2008 09:42 PM
Bypass Tone Pot with Fred? pedalinbob Pickups & wiring 2 04-09-2005 11:37 AM
Ibanez Wh10 Wah true bypass - how to install true bypass? stratman Gear, Equipment, Recording & Off Topic 1 01-04-2001 06:28 PM
