Edge design fault & Kramer - Jemsite
post #1 of 25 (permalink) Old 09-16-2009, 10:54 PM Thread Starter
In the untold story Ibanez book, it mentions that there was a design flaw with the nut with Ibanez's Edge interpretation of the OFR, and that Kramer didn't want Ibanez to find out, but Mr Floyd Rose pointed it out to Ibanez.
Anyone know more details about what the problem was?
bluffalo is offline
post #2 of 25 (permalink) Old 09-16-2009, 11:04 PM
Re: Edge design fault & Kramer
What's wrong with this picture
Rich is offline
post #3 of 25 (permalink) Old 09-16-2009, 11:27 PM
Reviews: 10
what's with the B-string?
and the pink lines on the headstock?
or are the hex sizes in standard?
maybe the huge gaps between the locking nuts?
jemmaniac is offline
post #4 of 25 (permalink) Old 09-16-2009, 11:38 PM
Too bad you edited.
Rich is offline
post #5 of 25 (permalink) Old 09-16-2009, 11:45 PM
Reviews: 10
Too bad you edited.
was i right the first time?
i've seen them both ways but i wasn't positive with that answer..
post #6 of 25 (permalink) Old 09-17-2009, 12:25 AM Thread Starter
Was it just really as simple as tightening the locks the wrong way around? I saw it too, but I thought it must have been something more than that.
Cool, thanks for the answer!
I too, was looking at the b string thinking something was causing that, but the rest of the pictures just show its just a normal broken string.
bluffalo is offline
post #7 of 25 (permalink) Old 09-17-2009, 12:32 AM
The pads were cast with the curve on the bottom in the wrong direction.
Rich is offline
post #8 of 25 (permalink) Old 09-17-2009, 12:35 AM Thread Starter
oh okay! awesome, thank you!
bluffalo is offline
post #9 of 25 (permalink) Old 09-17-2009, 05:48 AM
Originally Posted by bluffalo View Post
...and that Kramer didn't want Ibanez to find out...
haha! bye bye, Kramer...
nuno is offline
post #10 of 25 (permalink) Old 09-17-2009, 07:58 AM
so the curve under the bottom of the pad should be in line with the strings right? and not perpendicular.
eruji is offline
post #11 of 25 (permalink) Old 09-17-2009, 10:23 AM
Ayrton's Avatar
Yep...
Ayrton is offline
post #12 of 25 (permalink) Old 09-17-2009, 12:55 PM
The curve mates to the nut base. I should have said they cast them with the ^^^ tops in the wrong direction.
Rich is offline
post #13 of 25 (permalink) Old 09-17-2009, 01:07 PM
Ayrton's Avatar
I wonder if there is any difference in the distribution of pressure based on the bevel orientation?
I doubt it matters much (if at all), but an observation nonetheless.
Ayrton is offline
post #14 of 25 (permalink) Old 09-17-2009, 01:11 PM
The bevel is there so that it can be higher on one side, ie. straddle the low E and A strings. If you've even tightened one of these early pads, the bolt is only biting on the high side, and it squeaks and grinds.
Rich is offline
post #15 of 25 (permalink) Old 09-17-2009, 01:15 PM
these bits of trivia are so cool
C.Thep is offline
edge , floyd rose , kramer
Is it Steve Vai's Fault? michblanch Off-topic / Miscellaneous 20 09-30-2008 02:48 PM
Who's fault is it? Dino Off-topic / Miscellaneous 9 09-19-2008 01:44 AM
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
a fault in my VWH vine Courjan Ibanez JEM, UV, JS & Other Signature Models 13 07-01-2003 08:30 AM
Kramer guitar information? - Kramer Ripley here, need serial trapzilla All Other Guitars (including Prestige) 1 05-04-2001 01:13 PM
