Edge Pro Zero Point - Jemsite
post #1 of 14 (permalink) Old 10-22-2012, 11:19 AM Thread Starter
Edge Pro Zero Point
Hey everyone. Got a jem recently. Its been a real struggle. Any help is greatly appreciated. I installed the tremol-no aligned everything and the bridge is perfectly parrallel. Everything looks good. When I use the whammy bar, it never returns back to zero point. Its always either higher or lower thus taking me out of tune whenever I use the tremolo. I figured what Rich says is wrong with my knife edges is true and the need to be lubed up. So I take the bridge out lube everything just as he says and still nothing. Im losing hope here.
Thanks
Cristian
cpelaez is offline
post #2 of 14 (permalink) Old 10-22-2012, 11:23 AM
Re: Edge Pro Zero Point
Your problem is probably the T-No, not aligned, not lubed, just not letting the trem return right.
Rich is offline
post #3 of 14 (permalink) Old 10-22-2012, 11:25 AM Thread Starter
I took the t-bar out and just had the claw and springs and still the same thing. I dont know how else Im supposed to "align" the t-no. Ive done everything the video says on youtube and researched so much.
cpelaez is offline
post #4 of 14 (permalink) Old 10-22-2012, 11:31 AM
If the T-No is out then your problem obviously lies elsewhere. You'd have to explain exactly how it goes out of tune when you do exactly what.
Rich is offline
post #5 of 14 (permalink) Old 10-22-2012, 11:35 AM Thread Starter
When I bring the tremolo up and lower the pitch of the strings, the bridge stays a little higher and the notes go flat. When I bring the treomol down towards the cavity to make the notes sharp, the bridge stays a little lower and the notes are sharp.
cpelaez is offline
post #6 of 14 (permalink) Old 10-22-2012, 11:39 AM
Only tune after a dive so the bridge can only go sharp on pullup. Past that i'd be looking for something binding, touching, rubbing, something.
Rich is offline
post #7 of 14 (permalink) Old 10-22-2012, 03:02 PM
Is this a NEW guitar? If not, my thought is that the knife edges on the trem could be worn.
chrisolson is offline
post #8 of 14 (permalink) Old 10-22-2012, 03:06 PM
Springs!
There is another thread like this in progress right now.
sebastian is offline
post #9 of 14 (permalink) Old 10-22-2012, 04:34 PM
Reviews: 120
I have to ask, why have you made so many threads for this same issue? You've got like 3 or 4 now. Please in future stick to just the one thread. No need to clog it all up with multiples. All the information you receive is scattered across them and hard to keep up with. You end up with multiples of the same advice.
LonePhantom is offline
post #10 of 14 (permalink) Old 10-23-2012, 12:29 PM Thread Starter
sorry first time.
cpelaez is offline
post #11 of 14 (permalink) Old 10-23-2012, 12:30 PM Thread Starter
Originally Posted by sebastian View Post
Springs!
Where is the thread?
cpelaez is offline
post #13 of 14 (permalink) Old 10-23-2012, 12:49 PM Thread Starter
Its fairly new.
cpelaez is offline
post #14 of 14 (permalink) Old 10-23-2012, 03:21 PM
Too flat. It should have a slight forward tilt.
edge pro jem vai
Point to Point Proline PCB Robotalk Tech: Setup, Repairs and Mods 0 09-11-2009 09:59 AM
Pivot point length on an edge III? Softmod All Other Guitars (including Prestige) 1 08-10-2008 06:50 PM
whats the point of this........ a_nxiety All Other Guitars (including Prestige) 10 11-19-2007 09:17 AM
Hand wired point to point Fender style amps KDAD Gear, Equipment, Recording & Off Topic 0 04-15-2006 04:00 PM
RG-ART - got a contact point for one tomizm All Other Guitars (including Prestige) 18 04-01-2001 03:31 PM
