EL34 versus 6L6- please post advice - Jemsite
post #1 of 2 (permalink) Old 12-05-2001, 02:45 PM Thread Starter
Hey guys,
I have a Rectifier head and although im really pleased with the heavy sounds i get out of it, i want to know what kind of difference EL34 valves would make rather than the 6L6 MESA ones supplied with it.
I was considering buying some to swap them over, since the new models (like mine) have bias switches so its an easy switch.
Thanks,
Mark
mginty is offline
post #2 of 2 (permalink) Old 12-06-2001, 01:09 PM
mginty-
I have done this and I prefer the EL34's. I have two rect. heads so I am able to a/b them. The 34's seem to have a warmer sound IMO. Higher notes seem to ring through better but I do feel that 6L6's are cleaner and have a better bottom end "chunK"
Also, try pulling two of the power tubes.
I have a question for you:
What are your settings for the send and mix controls (effects loop) when you are not running anything throught the effects loop and have the selector switch on the foot controller setting (allowing you to use the solo)?
big al is offline
Fakes versus replicas versus customs dcord Off-topic / Miscellaneous 71 07-02-2010 03:23 PM
A long post about asking for tone advice kotornut Gear, Equipment, Recording & Off Topic 6 03-03-2008 04:40 PM
6L6 or EL34?? casper777 Gear, Equipment, Recording & Off Topic 30 03-02-2008 11:18 AM
can't take out a broken trem post, advice? j.arledge Tech: Setup, Repairs and Mods 9 11-15-2005 08:05 PM
6L6's or EL34's? rufes Gear, Equipment, Recording & Off Topic 1 03-29-2005 12:29 AM
