electric shock while recording - Jemsite
post #1 of 12 (permalink) Old 07-05-2007, 12:02 PM Thread Starter
i get electric shock in my strings when i try to record in my computer..
What could be the problem.. and its grounded properly.. plz help
could it be the problem of ATX box or power supply??
Shredtillubleed2death is offline
post #2 of 12 (permalink) Old 07-05-2007, 10:26 PM
Re: electric shock while recording
ahhhh no. ur producing static electricity somwhere. are u playing on a carpet floor? if so, there's your problem. ur building up static electricuty, and when u touch the strings, u release the charge and close the circuit. bam! ur shocked
yoyo1299 is offline
post #3 of 12 (permalink) Old 07-05-2007, 10:31 PM
actually, if you touch the strings of our guitar and then touch a microphone with your lips, like barely touching it, you get a little ´´licking a 9v battery´´ feeling on your lips... same goes for having your lips/face on the mic and barely touching the strings...
dunno why it happens, though...
MF_Kitten is offline
post #4 of 12 (permalink) Old 07-09-2007, 12:02 AM
elcid's Avatar
Are you positive everything is grounded correctly?
elcid is offline
post #5 of 12 (permalink) Old 07-09-2007, 04:42 AM
no offence but dont believe this nonsense...
There are several sources of shock which can be deadly... which gladly this one wasnt!!!
Its hard to figure out what is the cause exaclty but since it only happends when your recoding into your computer it must be a faulty earth in the computer somewhere... and unless your a computer whiz its going to be hard to find out where.. or fix it.. but first thing to try would obviously be replace the soundcard ... then next step would be the motherboard...
However, as an alternative... if you follow this link there is a simple mod you can do to your guitar (add 1 capacitor to the bridge ground) to prevent 'some' electric shock caused by dodgy equipment grounds...
http://www.guitarnuts.com/technical/...fety/index.php
Unfortunatly us musicians usually use ourselves as electrical testing equipment...
Good luck
Steve
Devo is offline
post #6 of 12 (permalink) Old 07-09-2007, 05:15 AM
Reviews: 6
Since i have an indoor TV antenna in my room, I've noticed that if i accidentally touch the antenna while i'm playing i get a nasty little shock a fair bit worse than licking a 9V, and using just that energy produced the guitar and amp, if i place an LED between me and the antenna it will light up, Its amazing how much electrical energy surrounds you when you play the guitar. So i would suggest the same as others, Check your grounding the energy is leaking from somewhere then onto your trem and onto the strings and when you play your completing the circuit.
Mike239 is offline
post #7 of 12 (permalink) Old 07-09-2007, 07:08 AM
An LED?? Wow thats crazy, I never would have thought!
Distantshore is offline
post #8 of 12 (permalink) Old 07-09-2007, 07:43 PM
Reviews: 6
Oh the LED was just to test how much voltage and current i had running through me when i play, it's a surprising amount about 2-3v.
Mike239 is offline
post #9 of 12 (permalink) Old 07-09-2007, 09:44 PM
Good luck
Steve
maybe this isn't the cause, but it's not nonsense. i've done it to myself (in other cases) a lot. just wearing a thick sweater then touching metal can give a shock.
yoyo1299 is offline
post #10 of 12 (permalink) Old 07-09-2007, 09:50 PM
rofl I'm always full of static except when I play guitar. I could probably put a led in my mouth and light it up at like publix but when I'm playing guitar I get nothing. Is your pc on a carpeted ground? or is it up on a desk?
newbieguitarmaker is offline
post #11 of 12 (permalink) Old 07-10-2007, 02:55 AM
Dino's Avatar
Dude, just go wireless and forget about it.
Dino is offline
post #12 of 12 (permalink) Old 07-12-2007, 01:58 PM
You have a ground issue. Static electricity can shock you of course, but you need to generate it, and simply standing still and playing your guitar W/O moving around AT ALL, will not do it.
Depending on how old your house is, the wiring could not be properly grounded. Are you plugging your guitar directly into the computer's sound card or into something else first?
If you are using two different circuits, one on the computer, one for the fx box whatever for the guitar, the polarity could be off. Try using a ground lift plug to remove either the guitar or the the computer from the loop. Just be careful though, as MF_Kitten pointed out
"... actually, if you touch the strings of our guitar and then touch a microphone with your lips, like barely touching it, you get a little ´´licking a 9v battery´´ feeling on your lips... same goes for having your lips/face on the mic and barely touching the strings..."
a ground issue at the very least can hurt, at the most it can KILL.
If you are not comfortable with trying to fix the issue, talk to an electrician. Good luck!
tobe is offline
playing guitar
Pictures of everyone's recording studio or recording gear rikkbeatty Gear, Equipment, Recording & Off Topic 38 08-22-2005 03:17 AM
Electric shock from a guitar barney Tech: Setup, Repairs and Mods 20 01-17-2005 01:16 AM
Need new recording setup Beavis Gear, Equipment, Recording & Off Topic 18 05-27-2002 07:47 AM
Recording Electric Guitar: Mic or direct out? - Which way is davester1234 Gear, Equipment, Recording & Off Topic 16 01-26-2002 03:47 PM
