EQ, Changing Pickups Tone - Jemsite
post #1 of 6 (permalink) Old 10-08-2005, 04:33 AM Thread Starter
hi!
so i have an idea and want to know will it work or no?
so here is the idea: i want to plug my guitar directly to EQ and then into fx chain (or amp, or multifx...). what i want to do with EQ? i want to change my pickups tone with that and nothing else. so i have one axe with 9 presets in my EQ (=with 9 pickups! ) lets take Hi-end like Boss Dual Peadal Advanced EQ with preests. expl: i'm playing jazz - i've killed hi's and boosted lows, so press pedal and turn on preset no.2 whre i kill lows and boost hi's, so here is my question? will i get strat like tone in this case?
i just whant to know if it's possible to get differet pu's tones from one pu and good EQ?
Toto is offline
post #2 of 6 (permalink) Old 10-08-2005, 04:49 AM
Re: EQ, Changing Pickups Tone
eq lets you subtract and boost across certain defined frequency ranges...its not going to turn an Air norton into a PAF pro or a pearly gates... sorry
Devo is offline
post #3 of 6 (permalink) Old 10-08-2005, 05:07 AM Thread Starter
http://www.roland.co.jp/BOSS/flash/point.html
listen to EQ-20 Advanced EQ's sound samples
Toto is offline
post #4 of 6 (permalink) Old 10-08-2005, 05:12 AM
Originally Posted by Toto
hi!
of course it is...
a highly flexible sound chain, in fact, should have equalization both before and after the gain stage, and finally be amplified (some suggest eq even after the power stage)
if you want to go deeper in this matter, have a read to this:
http://www.amptone.com/2eqswithpowerattenuator.htm
http://www.amptone.com/truesecretofamptone.htm
machinediva is offline
post #5 of 6 (permalink) Old 10-08-2005, 07:09 AM
that just proves my point... eq is very useful for tweaking sounds... but will not make a guitar with only a bridge evo pickup into a holow body jazz guitar.. make it sound like a neck pickup... or an acoustic.. as those sound clips would have you believe... i htink what you are looking for doesnt exist... the closest thing to what you want is rolands COSM.. like a VG-88... that will let you simulate lots of guitars and amps through one hex pickup.
Devo is offline
post #6 of 6 (permalink) Old 10-08-2005, 07:19 AM Thread Starter
thanks for links!
Toto is offline
air norton , neck pickup , paf pro
Changing vol/tone/switcher/tunerhead knobs Ibaneziceman1012 Tech: Setup, Repairs and Mods 2 04-13-2013 08:46 PM
Changing pickups on Jem BSB vibetronic Pickups & wiring 2 04-02-2007 10:44 AM
Aluminum pickguard. Is it changing my tone? john1880 Tech: Setup, Repairs and Mods 4 02-12-2006 10:42 AM
Changing pickups 6StringGod Pickups & wiring 1 12-10-2003 08:28 PM
Changing vol pot changes tone - Observations, anyone? Mr Orange Tech: Setup, Repairs and Mods 2 01-16-2002 01:32 AM
