FX Loop problems - Jemsite
post #1 of 8 (permalink) Old 06-02-2011, 05:44 PM Thread Starter
Reviews: 17
FX Loop problems
So my brother bought a DD3 today and we plugged it into the FX loop but the amp starts making a hum/buzz......is that normal?
Maybe we're plugging it in wrong? Do we put a NS-2 in front of it or something? We're kinda new to the whole FX loop thing so help would be appreciated.
Amp is a Peavey 6505. We are currently running a TS9 and NS-2 in front of the amp.
Speedabob is offline
post #2 of 8 (permalink) Old 06-02-2011, 05:47 PM
Re: FX Loop problems
Do you use batteries or power adapter to power the DD3? If it's the adapter, try sticking a battery in and see if that helps. Daisy chained supplies can create ground loops that cause terrible hum.
Cheers
bancika is offline
post #3 of 8 (permalink) Old 06-02-2011, 05:49 PM Thread Starter
Reviews: 17
We have a battery in all our pedals. we tried different leads too, no difference.
post #4 of 8 (permalink) Old 06-03-2011, 03:48 AM
If your still getting hum and running EVERY pedal on batteries, then i would think maybe a faulty pedal somewhere.
Try plugging the guitar directly into the amp, with the DD3 in the loop. If there is still hum, try different leads. Then try a different guitar, then try it without the DD3. If taking the DD3 out removes ur problem, get a replacement.
Toodles Julz!
julzius is offline
post #5 of 8 (permalink) Old 06-10-2011, 11:29 AM Thread Starter
Reviews: 17
i think the DD3 is the problem, Any idea what would need fixing on it? Because without it there is no hum.
post #6 of 8 (permalink) Old 06-10-2011, 11:36 AM
Reviews: 4
Delays and reverbs have a tendency to amplify small buzzes and make them loud, try some different settings, see if it changes, then try bypassing it. Are you using a battery or power supply? could be ground hum from a wall outlet to the PSU. just considerations.
fwd0120 is offline
post #7 of 8 (permalink) Old 06-19-2011, 03:07 AM
I wonder if the cable described here will help:
http://www.rjmmusic.com/blog/2011/06...-loop-problem/
Petie is offline
post #8 of 8 (permalink) Old 06-19-2011, 03:59 AM
there shouldn't be a ground loop if he's using batteries, but there's no harm in trying
bancika is offline
6505 , boss , dd3 , delay , hum
Use FX loop or not? ESPdude Gear, Equipment, Recording & Off Topic 7 04-27-2008 01:48 AM
fx loop help astro929 Gear, Equipment, Recording & Off Topic 1 01-14-2007 03:47 PM
Rg 3120 Problems. ANNOYING PROBLEMS!!!! Given to Fly All Other Guitars (including Prestige) 20 05-24-2003 01:24 PM
Problems using an effects loop-please help mginty Gear, Equipment, Recording & Off Topic 3 12-06-2001 03:46 PM
Legacy effect loop - possible ground loop hum? bill h Gear, Equipment, Recording & Off Topic 4 08-12-2001 03:05 PM
