FX600 Digital Effects (Behringer) Demo & Review - Jemsite
post #1 of 3 (permalink) Old 08-16-2018, 07:36 AM Thread Starter
SOUND:
The all-digital Behringer FX600 offers six different effects at 24-bit quality. Not only is the sound high resolution, but you can hook it up in stereo for true left/right channel imaging. The YouTube video below demonstrates the different patches at different settings, playing both clean and dirty:
A big plus is that the sound quality is crystal clear. The ‘quality’ of the effects is very decent for the price of $39.99 USD. In that regard, the Flanger is not as good as a dedicated $150 flanger, and the same is true for the Chorus, Phaser, Delay, Tremolo and Phase Shifter. But if you use the odd effect the odd time and you’re doing it on a budget, the FX600 is a solid investment.
OVERALL IMPRESSION:
Some musicians may consider the FX600 as an entry level pedal, particularly those long in the game and collecting pedals of all types and qualities. Although true in one regard, for $39.99 USD it produces some very decent sounds… and they are crystal clear to boot. Besides the clarity, I actually like the digital sound of these effects… there is something very futuristic and machine sounding. It may be suggested that the sounds are the result of less expensive guts or electronics, but it actually is part of the FX600’s charm. If you’re into ‘Industrial’ Metal, then you very well may like the FX600 for the ‘edge’ it offers, whereas others will like the pedal for its superb clarity and price point.
EASE OF USE:
There are other multi-FX pedals on the market, such as the Dr. Scientist BitQuest, and typically thyy tend to operate in a similar manner. You decide what effect you want with the FX Selector knob (far right): Flanger, Chorus, Phaser, Delay, Tremolo or Pitch Shifter. The LEVEL knob (far left) dictates the degree of mix or how much of the effect you hear. Around 12-noon and the effect is very audible, whereas 9-o’clock you can faintly hear it (a subtle effect)… and turned up full produces full effect with no dry signal. The other two knobs play different roles, depending on the effect chosen. When choosing Flanger, Chorus or Phaser the PAR 1 knob affects ‘speed,’ whereas the PAR 2 knob affects ‘depth.’ When choosing delay those knobs control ‘delay time’ and ‘delay feedback.’ When choosing Tremolo those knobs control ‘speed’ and ‘shape’ (LFO waveform). And when choosing Pitch Shifter the knobs control ‘detune’ (slight shifting for a fatter sound) and ‘semi tone’ (pitch interval, e.g., 3rd, 5th, octave, etc.). As stated, some effects are barely audible with both knobs at 9-o’clock (e.g., clean guitar and the Phaser effect), whereas others are very audible (e.g., dirty guitar and the Flanger effect). Consequently, 10-minutes of experimentation will help you to zero in on how the effects are used best.
RELIABILITY & DURABILITY:
The FX600 can hold up when gigging, so long as stomping is kept under control and the pedal board is not abused during transportation. However, the FX600 likely is best suited for home playing or those on a budget as the housing is made of plastic (with a rubber topper where the foot stomps to switch the device on and off). The knobs feel solid enough and turn smoothly. The four knobs and the small LED are on a lower level than the foot switch, and so they would not be in harm’s way. All in the inputs are along the side of the pedal, which makes sense since there are several (two stereo in and two stereo out, besides the power input). The inputs and outputs are set much lower than the foot switch as well, making it difficult to produce any force on the cables with regular use.
logicbdj is offline
post #2 of 3 (permalink) Old 08-16-2018, 12:53 PM
jim777's Avatar
Re: FX600 Digital Effects (Behringer) Demo & Review
Well, it is certainly cheap enough. Being an old person myself I would not want to be bending over and changing the effects at a gig, especially when are written that small, but i suppose if you are a bedroom player this might be worth the price. I also don't know what else they could have named it, but multi-effects has always meant multiple effects at once, which this doesn't appear to do.
jim777 is offline
post #3 of 3 (permalink) Old 08-16-2018, 02:38 PM Thread Starter
Well, the review did indicate that it is more for the home musician (for more than on reason) and apparently multi-effects has NOT always meant multiple effects at once since the FX600 has been around for a while and is actually called FX600 Multi Effects. The name proves the argument wrong.
logicbdj is offline
Quintessence Harmonizer (TC Electronic demo & review) logicbdj Gear, Equipment, Recording & Off Topic 6 06-05-2018 09:10 AM
Happiness by Dwarfcraft (demo & review) logicbdj Gear, Equipment, Recording & Off Topic 0 02-17-2018 08:58 AM
FS: Digital Mixer Behringer DDX3216 Haipong Classified Ads: Guitars and Gear 0 10-02-2014 06:33 PM
-FS- ORIGINAL IBZ V Pickups! / Behringer PRO8024 Digital 31 band EQ RACK ClassicAxe Classified Ads: Guitars and Gear 3 08-01-2006 05:14 PM
Korg PXR4 Digital Recorder - Review & Demo MP3's bduersch Gear, Equipment, Recording & Off Topic 2 11-29-2002 12:12 PM
