G-Major and blackstar HT-5 head - Jemsite
post #1 of 8 (permalink) Old 08-13-2009, 07:28 PM Thread Starter
i was wondering if anyone was playing a G-Major through there blackstar HT-5 head? if so how well does it do? or has anyone heard one go through the head. if not do you guys think it would work good? thanks.
paul
big_paul_ski is offline
post #2 of 8 (permalink) Old 08-14-2009, 03:53 PM
Reviews: 57
Re: G-Major and blackstar HT-5 head
While I have no direct experience with the head you mention, I do notice that it has an effects loop with a switchable level. So you should have zero problems with the g-major (gm) in there. The gm can do line or instrument level anyway, but set your effects loop to line (+4), and run it into the gm (set also to line level) and you're all set.
The gm is very transparent, and sounds fine in almost any setup. The unit isn't going to change anything other than by whatever effects you set.
blackspy is offline
post #3 of 8 (permalink) Old 08-14-2009, 04:03 PM Thread Starter
can you please explain what you mean by set to line +4 and what is the difference between line and instument level like you ststed? sorry about this i have never had an amp head or used an effects loop. does that amp have a line 4? and thanks.
post #4 of 8 (permalink) Old 08-14-2009, 05:23 PM
Reviews: 59
Hey Paul, I believe he's referring to the signal db level. Some effects put a level out at +4, others at -10db. The blackstar will adjust to accomadate that signal level. Otherwise, your sound quality suffers and things can get noisy.
smooth55 is offline
post #5 of 8 (permalink) Old 08-15-2009, 09:14 AM
Reviews: 57
^^ Exactly... The G-Major will support +4 or -10 db, as does your head. Just make sure they match.
blackspy is offline
post #6 of 8 (permalink) Old 08-15-2009, 11:47 AM Thread Starter
so there is a place on the back of the amp to adjust this?
post #7 of 8 (permalink) Old 08-15-2009, 12:15 PM
Reviews: 15
Yes, there's a little button next to the effects loop jacks.
MarkE is offline
post #8 of 8 (permalink) Old 08-15-2009, 12:28 PM Thread Starter
thanks for the info Mark.
Blackstar HT-5 review LonePhantom Gear, Equipment, Recording & Off Topic 30 11-04-2011 11:04 AM
Blackstar HT-5 head users big_paul_ski Gear, Equipment, Recording & Off Topic 0 08-12-2009 09:55 PM
Blackstar HT-5 or possible rebel 30 big_paul_ski Gear, Equipment, Recording & Off Topic 24 07-26-2009 05:50 PM
Blackstar Nick83 Gear, Equipment, Recording & Off Topic 0 05-12-2009 03:33 AM
Thinking about getting a blackstar ht-5.... cmd130 Gear, Equipment, Recording & Off Topic 1 03-18-2009 02:33 PM
